Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Closed Thread
Old 07-02-2003, 10:45 PM   #1
Crash Dummy
CF Senior Member
St. Jude Contributor
Crash Dummy's Avatar
Default Hedman sidepipe headers... anyone tried these?
I just got these today. Appears they may be a workable solution to hooking to my factory sidepipes on this new engine. I had already cut away the pipes going up to the old cast iron exhaust manifold, so hopefully it is nothing but cutting them again to the correct length... install the adapters... and bolt them up. I know it's not going to work that way, but this should expedite finally firing this motor up.
Crash Dummy is offline
Old 07-02-2003, 11:47 PM   #2
tshort
CF Senior Member
CI 7-8 Veteran
tshort's Avatar
Default Re: Hedman sidepipe headers... anyone tried these? (bgrice)
Barry - Glad to see you haven't given up on it yet. Hopefully I can get mine legal (and the new fuel pump problem fixed) and come over and help you finish yours. Once you start it up again I'm sure you'll wonder why the hell you were ever thinking about selling it.
tshort is offline
Old 07-03-2003, 01:15 AM   #3
427V8
C6 the C5 of tomorrow
Support Corvetteforum!
427V8's Avatar
Send a message via AIM to 427V8
Default Re: Hedman sidepipe headers... anyone tried these? (tshort)
Yep ran them for years. But when the 434 was don I had to go to something a little bigger :cheers:
427V8 is offline
Old 07-03-2003, 01:27 AM   #4
Crash Dummy
CF Senior Member
Default Re: Hedman sidepipe headers... anyone tried these? (427V8)
427V8....
Did they bolt right up with cutting the existing pipes to length or did you have to do some pipe bending to match? Just curious. I'll attack this Friday and take some pix as to how it works out.
Travis...
I love these C-3's. I just don't think they like us amateur mechanics fukkin with'em. :cheers:
Old 07-03-2003, 08:41 AM   #5
ED DINAPOLI
CF Senior Member
ED DINAPOLI's Avatar
The Hedman sidepipe headers have been installed for 4 years on my 74 SB. They bolted up without any problem. They are a little tight on the power steering valve and the idler arm, but no mods were necessary. I had them matched up to factory style sidepipes, but did not like the sound and they were too restrictive. Made a 3 inch setup and it sounds great with no restrictions.
Ed
ED DINAPOLI is offline
Old 07-03-2003, 09:23 AM   #6
Twin_Turbo
CF Senior Member
Default Re: Hedman sidepipe headers... anyone tried these? (ED DINAPOLI)
I have a set of those too (somewhere). The hooker quality is better but i like the design of these headers better, I don't really like the collector at the bend (it just lloks weird to me, those 4 into 1 pipes)
Ed, can you take some shots of how the side pipe bolts up to your headers? Sounds interesting (how you fabbed the side pipes).
never had it on the chassis though, I ran a dual 3" system w/ borla's and early stule crossmember. I only use those for engine break in on the stand.
[Modified by Twin_Turbo, 7:27 AM 7/3/2003]
Twin_Turbo is offline
Old 07-03-2003, 11:23 AM   #7
Barry's70LT1
CF Senior Member
Barry's70LT1's Avatar
Hi Barry,
I have been using these for over 20 years. (On the Second set now).
No problems at all.
Barry
Barry's70LT1 is offline
Old 07-03-2003, 12:31 PM   #8
ED DINAPOLI
CF Senior Member
Default Re: Hedman sidepipe headers... anyone tried these? (Twin_Turbo)
Twin_Turbo,
I dont have any pictures of the connections, but they connect the same way you would with the factory style pipes. I had a muffler shope make a collector connection on a 3 inch pipe, follow the route of the factory style pipe around the frame. Inserted 2, four inch round race mufflers and attached a 3.5 inch turnout on the end. The pipe is attached to the frame in a very similar manner as the factory style pipe.
Ed
Old 07-03-2003, 04:26 PM   #9
Twin_Turbo
CF Senior Member
I don't have or have had factory side pipes and don't know from the top of my head how they look under the covers so anyone with a pic, please post it here
Old 07-03-2003, 06:08 PM   #10
Crash Dummy
CF Senior Member
An update.....
I decided to attempt to put the driver's side header on this afternoon as I figured it would be the hardest. Since I had already cut away the pipes going downward from the old stock exhaust manifolds it made it alot easier. Installing the headers is a piece of cake compared to Hookers. Just raised the driver's side about 8-10 inches and slid the headers in. From the top I raised them up and they bolted right up. The only thing left was to measure how much more to cut off the existing pipes.... slide the adapter over and bolt them up. I still need a couple of muffler clamps and I will probably have the adapters welded to the sidepipes. I'll attack the other side tomorrow.
[Modified by bgrice, 4:09 PM 7/3/2003]
Old 07-03-2003, 10:52 PM   #11
tshort
CF Senior Member
CI 7-8 Veteran
tshort's Avatar
Barry - I hope your heads aren't angled plug design. If so, those headers will run into the plugs.....unless you can find the Accel shorty's that match your heads.
tshort is offline
Old 07-04-2003, 12:03 AM   #12
Crash Dummy
CF Senior Member
Now that you mentioned it I needed to go try the plugs before I went even further. The Dart heads are straight, but that would have really pissed me off to find out that there would have been interference. I have to admit that Sanderson designed things easy to work around and these Hedman headers take some time to align the plugs. Appears everything will work though. I'll put on the other side tomorrow and drop the mini-starter into a box for now. With these headers I can go back to the stock starter. The reasoning? I'm not sure what is going on, but I'm still having serious problems with the starter not dissengaging with the flexplate. It's a new flexplate... 168 tooth... maybe a bad one... I don't know. Either way I will not start this engine up this weekend. I will head out Saturday and get distilled water, fresh gas and the clamps I need.
Tomorrow evening? Get drunker than a coot for the 4th. :cheers:
Reload this Page Hedman sidepipe headers... anyone tried these?
Closed Thread
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
