Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-02-2003, 08:51 PM   #1
Indynut
CF Senior Member
Indynut's Avatar
Default Drag Racing question
I know I should really post this in the drag racing section but.........
In my search to go a little quicker each trip down the track, I really wanting to go with a slimmer tire on the front. I street drive my car alot but it just doesn't make sense to race with those big stock wheels (1979). I'd like to put something like 3.5" or 5" max up front. Any ideas would be a help. I know all about the caliper clearance problems, but need to find the way around it. Who's got the problem beatin?
Indynut is offline   Reply With Quote
Old 07-02-2003, 09:08 PM   #2
GrandSportC3
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
St. Jude Donor '03-'06
GrandSportC3's Avatar
Send a message via AIM to GrandSportC3 Send a message via Yahoo to GrandSportC3 Send a message via Skype™ to GrandSportC3
Default Re: Drag Racing question (Indynut)
I just got some skinny front rims (15 x 3.5) with 165 R 15 tires...
They didn't clear the calipers.. so - I ordered 1 inch wheel adapters for $65 off Ebay... You could also get Centerline Auto Drag or Convo Pro Skinnies that should clear the calipers.
GrandSportC3 is offline   Reply With Quote
Old 07-02-2003, 09:09 PM   #3
bence13_33
CF Senior Member
bence13_33's Avatar
One solution is to keep your current tires and fill them to about 40psi of air. I do this with my car. There are two main benefits. The first being that a tire with more air will roll easier. The second reason is that when you pump the tire up it will move the front end up slightly...this aides with the weight transfer.
How fast are you running. I'm running low 12s with stock rims up front. I doubt you will see much of an increase in speed. If I would do anything I'd get rid of the heavy Chevy rally rims. The rims are rotating mass. Any weight that you shave off of them is worth 5 times that. For instance say you switch rims and shave 15lbs off of the rear rims. That's the equivelent to shaving off 150lbs....which is .15 in the 1/5 mile.
bence13_33 is offline   Reply With Quote
Old 07-02-2003, 09:44 PM   #4
Clink69
CF Senior Member
Clink69's Avatar
Default Re: Drag Racing question (bence13_33)
:iagree: this is what I do. I put 235/15s on the front using my aftermarket Alum rims.
Clink69 is offline   Reply With Quote
Old 07-02-2003, 09:51 PM   #5
GrandSportC3
CF Senior Member
Cruise-In V Veteran
The stock rims are pretty heavy indeed.. including the factory alloys... Some light weight Drag Race wheels can make a lot of difference in you ET... You might even be able to take .2 - .3 off your ET just because of the weight savings...
Old 07-02-2003, 10:17 PM   #6
Crash Dummy
CF Senior Member
St. Jude Contributor
Crash Dummy's Avatar
Default Re: Drag Racing question (GrandSportC3)
Just don't expect those small drag tires on the front to last any time at all on the streets. They are designed for straight.... not day to day cornering on rough concrete.
Crash Dummy is offline   Reply With Quote
Old 07-02-2003, 10:24 PM   #7
Jvette73
CF Senior Member
Jvette73's Avatar
I wish I had the money..ide get me some pizza cutters for the front and some slicks for the rear and mount em on the lightest wheels I could find. I would use em at the track only and save my radials for the street. I have a ball of rubber ive been adding to from the rubber stuck to the fender wells and quarter panels. Its almost the size of a tennis ball.
Jvette73 is offline   Reply With Quote
Old 07-02-2003, 10:38 PM   #8
isosceles
CF Senior Member
isosceles's Avatar
I'd be willing to bet you'd no longer be able to take a corner at a decent speed without massive understeer. :eek:
isosceles is offline   Reply With Quote
Old 07-02-2003, 11:07 PM   #9
Indynut
CF Senior Member
Indynut's Avatar
I do plan on using my stock wheels and TA's for my daily driving needs but I really make it better at the track. I have been running with 40 PSi up front on race day. That's only until I get this sorted out. Does anyone have pics of their set-up?
Thanks again everyone!
Indynut
Old 07-02-2003, 11:19 PM   #10
GrandSportC3
CF Senior Member
Cruise-In V Veteran
Default Re: Drag Racing question (bgrice)
I'm not going to use them on the street....
Old 07-02-2003, 11:21 PM   #11
GrandSportC3
CF Senior Member
Cruise-In V Veteran
Default Re: Drag Racing question (isosceles)
Skinnies are for drag race use only.. It's not a good idea to use them on the street.. It could be even dangerous...
Old 07-02-2003, 11:21 PM   #12
Glensgages
CF Senior Member
Glensgages's Avatar
Send a message via AIM to Glensgages
Indynut, tho' I don't run 'skinnies' on my Vette, I do run them on my '79 Z28. If you go this route, and choose to run 'Mickey Thompson' 26" tires, the SUMMIT catalog shows two different tires in the same size. MAKE SURE you get the ones built for 3000+ pound vehicles; I ran the 'other' ones for a while (my Z tips the Toledos at 3800+), and even at 'just' 105 MPH, they were a bit unstable. The 'correct' tires got rid of any problem :thumbs:
Glensgages is offline   Reply With Quote
Old 07-03-2003, 11:39 PM   #13
Indynut
CF Senior Member
Indynut's Avatar
Thanks, now I'll start hunting. Hope to see someone adding a few pics to this post. Somebody must have a pic! Thanks gang!
Indy
Reload this Page Drag Racing question
Tags
cornering, corvette, skinnies
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Nitto Drag Radials/Drag Racing Question XTrooper Performance Results 31 11-06-2004 06:32 PM
Viper Drag Racing question? gkull Drag Racing 16 09-19-2003 04:54 PM
Drag Racing Question -- Is 12.8 @ 101-102 possible?? YLO Z06 Drag Racing 9 09-02-2003 07:01 PM
Drag racing question regarding shift points NC_EB_Z06 C5 Z06 Discussion 37 11-16-2002 09:28 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
