Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-02-2003, 01:40 PM   #1
75 BBC Stingray
CF Senior Member
75 BBC Stingray's Avatar
Default Body Lift Question - Front Clip
So I've got the body mount bolts out. The engine and transmission are out. I've still got to detatch the emergency brake cable, the battery ground, and the frame to seat mount tethers. I also need to look at the rear bumper attachment to the frame.
Question regards the front clip. Almost all of the photos I've seen of body-off frames don't have the front clip support/vacuum resevoir attached to the frame. So do I undo the 4 bots on each side of this frame member and hoist it with the body? Seems heavy out there unsupported like that...
Opinions? Comments?
[Modified by 75 BBC Stingray, 4:47 PM 7/2/2003]
75 BBC Stingray is offline   Reply With Quote
Old 07-03-2003, 01:11 PM   #2
75 BBC Stingray
CF Senior Member
Default Re: Body Lift Question - Front Clip (75 BBC Stingray)
ttt
Old 07-03-2003, 01:34 PM   #3
topless68
CF Senior Member
topless68's Avatar
Location: Your Fighting Tigers of LSU. 2003 National Champs
I'm not sure what you are asking, but I did not have a resevoir to remove.
But if it's an easy thing to remove, why not go ahead and pull it?
topless68 is offline   Reply With Quote
Old 07-03-2003, 01:45 PM   #4
NHvette
CF Senior Member
NHvette's Avatar
EDIT : This discusses my '75. The early C3s are significantly different.
One of my biggest mistakes (but not too fatal) - was to leave that frame extension
on the front end when I took the body off. Over time, the weight started to
crack around the front corners of the fenders. That's OK - it needs a good
going over, anyway.
First, you need the front bumper cover removed. This gives access to two bolts
on each end of the inner bumper cushion (honeycomb). these bolts go to the
outer bumper brackets, which are also held on by the frame extension bolts.
You said four bolts - but there is a hidden one behind this outer bumper bracket.
So - get the outer bracket off and you'll be half-way there. I assume you
already broke all the bolts off to remove the lower front valence panel and
spoiler. Take out all the grills/etc. If you want to take it out in pieces, then
the bumper brace/honeycomb can be unbolted from the front of the frame
extension. Don't forget the two bolts at the bottom. This may also have a
mount at the very front/center of the nose. Mine was rotted away - so no clue
there.
If you get the valence panel out of the way - you can leave the frame extension in place (on the frame).
Definitely get these heavy pieces out before lifting the body.
Look in my website (in sig). I have some pics of my rusty 75 that might not
help. Also, look in the 70 pics - there is a section that shows us removing the
front fenders. Unfortunately, I don't have any pics up that show exactly what
you are doing.
Be prepared to replace the bumper cover. I'm going fiberglass on that.
send me an IM - if you need more help. :seeya
[Modified by NHvette, 12:54 PM 7/3/2003]
NHvette is offline   Reply With Quote
Old 07-04-2003, 05:36 PM   #5
75 BBC Stingray
CF Senior Member
Default Re: Body Lift Question - Front Clip (NHvette)
Dave,
Thanks, the "frame extension" was exactly the piece that I was talking about. I called it a resevoir because it also supplies vacuum to the lights. I had thought I was pretty close to being able to remove the body, but had forgot about the bumpers! :banghead: My hope is to do minimal disassembly on the body so that I can have the body back down on the frame by next spring to drive. I don't want to risk having a car project that I can't drive for 2 years - too great of a danger of loosing interest.
My overall plan was to do frame, suspension, brakes, engine, drivetrain this winter. I would then drive it by next fall 2004, then work on the body that winter.
I will be working Saturday and Sunday on the car and will look for any other problem areas where I have questions and IM you.
-Greg
[Modified by 75 BBC Stingray, 4:37 PM 7/4/2003]
Old 07-04-2003, 05:58 PM   #6
mrvette
CF Senior Member
mrvette's Avatar
IF you are happy with the cowling as not needing rebuilt anyway....
remove the headlights, those damn things are heavy as hell....undu stress....
GENE
mrvette is offline   Reply With Quote
Reload this Page Body Lift ? - Front Clip
Tags
75, body, c1, c3, champs, checklist, clip, corvette, corvettte, front, lift, stingray
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
OUCH! I was warned to support the front clip (dialup beware) 73Gator C3 Tech/Performance 34 03-03-2004 05:10 PM
Body Dolly JLMvette73 C3 Tech/Performance 12 08-02-2003 04:56 PM
Body Mount Replacement or Shims Without Removing the Body Blkblt C1 & C2 Corvettes 16 10-25-2002 12:13 AM
Mid Year Body Panel Alignment gaser C1 & C2 Corvettes 30 09-10-2002 06:53 PM
Infamous 69 convert lift-collapse car FS 69L71 C3s for Sale/Wanted 10 04-22-2002 05:42 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
