Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-02-2003, 02:05 AM   #1
Cole Neadow
CF Senior Member
Default 1968 Ammeter ???s
The ammeter on my 68 is not working, I have two wires on the plug on the gauge, one has power all the time the other never has any, key on off or car running. I took the ammeter to the bench and tried putting a battery charger through it to a battery but nothing went to the battery so I thought the ammeter was defective, then I hooked an ammeter my son had(not Corvette) to the wires in the car to try them and it did'nt work either. Any ideas, what am I doing wrong :confused:
Thanks Cole
[Modified by Cole Neadow, 12:29 AM 7/3/2003]
Cole Neadow is offline   Reply With Quote
Old 07-02-2003, 06:55 PM   #2
Cole Neadow
CF Senior Member
Default Re: 1968 Ampmeter ???s (Cole Neadow)
no 68 owners :sad:
Old 07-02-2003, 07:51 PM   #3
LAWTON54
CF Senior Member
The problem is caused in most cases by a blown fusible link. Follow the the wire coming out of the voltage regulator and inspect all fusible links.
LAWTON54 is offline   Reply With Quote
Old 07-02-2003, 08:10 PM   #4
Boofers
CF Senior Member
Boofers's Avatar
Location: Winner of the 2006 cotter pin bending championship in Hamilton Ontario
Just so you know, its ammeter, not that its a big deal :p:
Ammeters have a very small internal resistance and are connected in series with the load. If you have a multimeter with an ammeter setting put it in series with your car's ammeter. If your multimeter's ammeter reads current but your car's does not you could have a bad ammeter. Although, if your car's ammeter is bad it may not allow current to flow through it at all. Does the car's ammeter have an internal fuse? Multimeter ammeters do have a fuse inside. Did you try your son's in the charger/battery circuit?
Boofers is offline   Reply With Quote
Old 07-03-2003, 01:23 AM   #5
Cole Neadow
CF Senior Member
Default Re: 1968 Ampmeter ???s (Boofers)
My sons ammeter did work in the charger/ battery test.
P S because I know I will get nailed by someone on my crappy spelling I even checked a parts catalog for the right spelling of ammeter, and as luck would have it I picked Riks who spells it wrong :rolleyes:
Old 07-03-2003, 01:26 AM   #6
Cole Neadow
CF Senior Member
Just wanted to add that my car is charging but the ammeter does not show that it is
Thanks Cole
Old 07-03-2003, 11:00 AM   #7
Boofers
CF Senior Member
Boofers's Avatar
Thanks for the update. Its always nice when people post the results of their troubleshooting.
Old 07-04-2003, 01:38 AM   #8
Diode
CF Member
Diode's Avatar
An ammeter is just an internal very low value shunt resistor (piece of tungsten wire sometimes) with a voltmeter across it. If the battery is charging but the ammeter isn't moving, the resistor is OK but the meter movement (the 'voltmeter' part) is shot. If the resistor is open, the ammeter won't move, but the battery won't charge either (since the resistor is internal to the ammeter, it can't be replaced. In either case the ammeter has to be replaced. The only other way for the ammeter to not read and the battery charge is if somebody 'jumped out' the ammeter circuit bypassing it. For example, connecting the 'Bat' terminal on the alternator directly to the battery instead of through the ammeter. If you need some diagrams to help explain this stuff, let me know. Hope this helps.
Diode is offline   Reply With Quote
Reload this Page 1968 Ampmeter ???s
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
