Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-01-2003, 11:53 PM   #1
69stingray
CF Senior Member
69stingray's Avatar
Default Mystery 430 Engine
Just reading my How to Restore & Modify your Corvette 1968-82 and the big block engine section mentioned that Chevy was reseaching a 430 engine to replace the 427. The secret was that it had a 4.44" Bore x 3.47" stroke vs. the 4.25" Bore and 3.76" stroke of the 427. Interesting. Too bad they did not go forward with it :(
69stingray is offline   Reply With Quote
Old 07-02-2003, 01:28 AM   #2
442olds
CF Senior Member
Default Re: Mystery 430 Engine (69stingray)
I believe the mystery engine your speaking of was actually the engine that chevy put together for the can am series. I think they even went larger than 430 later on in an all aluminum engine before the series was dropped. They made a ton of power and revved like you wouldn't believe.
442olds is offline   Reply With Quote
Old 07-02-2003, 01:53 AM   #3
pillowmeto
CF Senior Member
pillowmeto's Avatar
Send a message via AIM to pillowmeto
is there any where i can get my hands on one of those engines for less than 100 grand
MAtt
pillowmeto is offline   Reply With Quote
Old 07-02-2003, 01:57 AM   #4
LAvetteman
CF Senior Member
St. Jude Contributor
Default Re: Mystery 430 Engine (pillowmeto)
Ahhhh, that must be the"special ordered" engine that old man said was in his 95 I looked at..... :rolleyes:
LAvetteman is offline   Reply With Quote
Old 07-02-2003, 05:30 AM   #5
Fevre
CF Senior Member
Fevre's Avatar
I read about that one, it was in a mid year. Put out around 600 or 700 hp. Was way more powerful than that hoped, seems they only made 2 or 3 of them.
Wait, I might be confusing it with the 377 sb that was raced. It had a unique bore/stroke that is no the same as the destroked 400.
[Modified by Fevre, 8:31 AM 7/2/2003]
Fevre is offline   Reply With Quote
Old 07-02-2003, 09:16 AM   #6
e3pres
CF Senior Member
St. Jude Donor '08-'09
e3pres's Avatar
Send a message via AIM to e3pres
That's seems like a great idea, because most of an engine's frictional losses come from piston/cylinder wall interaction. A larger bore and shorter stroke seems like it would make the engine more efficient and able to handle more RPM's since the MPS would be lower.
e3pres is offline   Reply With Quote
Old 07-03-2003, 08:14 PM   #7
69stingray
CF Senior Member
69stingray's Avatar
Is there a way to get to 4..44" Bore & 3.76" stroke? Offset grinding with sleeves?? :crazy:
Old 07-03-2003, 10:42 PM   #8
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
a 502 block has a 4.470 bore and just add a 3.5 stroke crank.
clem zahrobsky is offline   Reply With Quote
Reload this Page Mystery 430 Engine
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
L-82, L-88, LS-1.....??????? GRAYGHOST C3 Tech/Performance 15 04-23-2004 02:03 AM
LT1 Camshaft Selection - Max HP & Torque wheeljo2 C4 Tech/Performance 10 06-23-2003 09:22 PM
Anybody use AI heads/cam 417 rwhp!!! Hammer C4 Tech/Performance 48 01-27-2003 10:28 PM
C3P/Historical/ZL-1 Road Test DJ Dep C3 Tech/Performance 76 01-10-2003 01:18 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
