07-01-2003, 06:08 PM
CF Senior Member
Re: Whose running BFGoodrich Radial T/A's (bloodvette80)
i am buying 255/60/15's all the way around
07-01-2003, 06:11 PM
CF Senior Member
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Re: Whose running BFGoodrich Radial T/A's (Alwyn678)
255/60/15 all the way around. No rubs, no problems. Just good smooth riding tires IMO. Plus they just have that muscle car look to them.
[Modified by Eddie 70, 5:11 PM 7/1/2003]
07-01-2003, 06:15 PM
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
St. Jude Donor '03-'06
That's what I use on the street...
For the strip I use 275/60R15 BFG Drag Radials in the rear..
and very soon 165 R 15 Metric Radials in front on 15 x 3.5 inch skinnies :D :D
07-01-2003, 07:37 PM
CF Senior Member
Re: Whose running BFGoodrich Radial T/A's (GrandSportC3)
I run 245's all around and they work, not the best tire for traction or handling either wet or dry but they are round and look nice.
07-01-2003, 07:40 PM
CF Senior Member
Re: Whose running BFGoodrich Radial T/A's (gdh)
I had them and recently switched to Firehawk SS20's. :thumbs:
07-01-2003, 07:47 PM
CF Senior Member
Re: Whose running BFGoodrich Radial T/A's (Eddie 70)
Same here
07-01-2003, 08:19 PM
CF Member
Re: Whose running BFGoodrich Radial T/A's (PatG)
it must be trendy - that's what I have on the '79 -
no problems, looks great :chevy
07-02-2003, 12:03 AM
CF Senior Member
Re: Whose running BFGoodrich Radial T/A's (Rooster)
I also have the 255/60-15
There are not very many choices available if memory serves me, mine are getting a touch skinng, Corey whats with the FireHawk's SS20's? Do you like them? Do they have a "newer" tread design and profile? Seems like "everone runs the BF Goodrichs, not bad but like to be a touch different.
[Modified by Mr69Vett, 10:09 PM 7/1/2003]
07-02-2003, 12:25 AM
CF Senior Member
St. Jude Contributor
Re: Whose running BFGoodrich Radial T/A's (Mr69Vett)
:seeya 255's in back. 225's in front.
07-02-2003, 12:52 AM
CF Senior Member
I put 4 BF Goodrich 260 R 15 TA's on all 4 coners of my 79. They have a great profile, they are quiet and handle great in all conditions. For the $160.00 per tire, you can't beat the value of this rubber. These are
Great Tires. :D :steering:
07-02-2003, 03:08 AM
CF Senior Member
Cruise-In V Veteran
Location: If you can read this, thank a teacher. If it is in English, thank a veteran.
235/60R15's on all 4 corners.
07-02-2003, 04:09 AM
CF Senior Member
I've got 255/60-15's on all 4. Not too good for traction, and make a lot of noise when I break them loose. But, can't put down the price and they will last a long time. My next tires will hopefully be more like the dunlop Sport 8000 in 245/50-15's. A bit more pricey, but a lot better rubber.
07-02-2003, 08:36 AM
CF Senior Member
:D
07-02-2003, 09:26 AM
CF Senior Member
255/60/15 all the way around. I can't go any larger in the front. They would rub.
07-02-2003, 09:31 AM
CF Senior Member
Re: Whose running BFGoodrich Radial T/A's (TonyQT)
295/50/15 rear and 265/50/15 front. I have an eye on Yokohama Avid S/T, but they don't import them to europe, so I will stay with BFG.
07-02-2003, 10:58 AM
CF Senior Member
BFGoodrich Radial T/A's on both vettes. 275's in the back and 255's in the front on the black vette. 225's all around on the red vette.
07-02-2003, 11:23 AM
CF Senior Member
These are the only tires I buy for ALL my vehicles. My Buick Park Ave has
225/70s, Blazer has flotation size offroad TAs, and the vette will be getting
the 255/60s.
:seeya
Tags
15 , 165r , 2556015 , 260r15 , 2655015 , 265x50x16 , bf , bfgoodrich , corvette , goodrich , make , radial , radials , ta , tires
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
