Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-01-2003, 04:30 PM   #1
WESCH
CF Senior Member
WESCH's Avatar
Default paging Lars and all other carb gurus.
Hello
I finally got a bigger carb to try on my engine.
The engine is a 427 CI .030 over with L71 square heads, 2.19/1.88 valves,
solid lifter cam .520/.520 lift, 242/242 duration at .050 , 114 degrees lobe centerline angle.
Until now, I was running a 650 CFM HOLLEY 4150 double pumper carb, no choke.
I now received a 4010 HOLLEY double pumper 750 CFM carb, no choke.
What size power valves, primary & 2nd needles should I run ?
The carb came off a small block stroker engine and I presently have no idea whats inside.
Will check it up this W/E.
Thanks a lot. Gunther :seeya
WESCH is offline   Reply With Quote
Old 07-02-2003, 05:51 AM   #2
WESCH
CF Senior Member
WESCH's Avatar
Default Re: paging Lars and all other carb gurus. (WESCH)
Hi
Even if no news is good news, I bring this back up to the top.
Thanks Gunther
Old 07-02-2003, 12:25 PM   #3
lars
CF Senior Member
lars's Avatar
Location: At my Bar drinking and wrenching in Lafayette Colorado
WESCH -
On unknown carbs, I always like to put them back to their stock, baseline configuration forst, and then tune from there. If you post up the list number, I can give you the stock specs for it. Give it a rebuild with an original Holley kit & parts, set your primary AND secondary idle speeds up correctly, level out the floats, and crack the idle mix screws to 1 turn out from seated. A 6.5 power valve works pretty good for most applications. Once set up and running, pull a couple of plugs and do a plug reading to determine if you need to bump the jet size up or down a notch or two.
lars is offline   Reply With Quote
Old 07-02-2003, 03:36 PM   #4
WESCH
CF Senior Member
WESCH's Avatar
Default Re: paging Lars and all other carb gurus. (lars)
Hello
Thanks for your answer.
This carb just received a HOLLEY kit.
I got the old parts with it. Both float vlv, both powervalves , both inline filters.
It doesn't look like if the prim and 2nd needles got repl.
The old power valves are 65th , so I suspect the new once being the same.
The 4010 carb is a R84013-1 , dated 2392.
I guess, I can just install it and try it out.
Lars, which book can you recommend for HOLLEY overhaul/tuning that also explains the function of the components ?
And thanks for your previous help on my ignition adjustment. Man, this engine never worked so good ! When it reaches 3500 RPM, it's like a afterburner.
I hope to get even more out of it with this carb.
Thanks. Gunther
Old 07-02-2003, 05:07 PM   #5
Boofers
CF Senior Member
Boofers's Avatar
Location: Winner of the 2006 cotter pin bending championship in Hamilton Ontario
Who is Gunther?
Boofers is offline   Reply With Quote
Old 07-02-2003, 05:37 PM   #6
Lasse
CF Senior Member
Lasse's Avatar
You have the standard setup of your carb on the ninth page in this pdf.
http://www.holley.com/HiOctn/ProdLine/CarbList.pdf
If you want a good explanation of the functions, check out this page:
http://www.bob2000.com/carb.htm
or Lars paper, but I can't find it.
Good luck!
[Modified by Lasse, 10:47 PM 7/2/2003]
Lasse is offline   Reply With Quote
Old 07-02-2003, 05:54 PM   #7
Lasse
CF Senior Member
Lasse's Avatar
Quote:
set your primary AND secondary idle speeds up correctly.
Lars - Is it the exposure of transfer slots you mean?
How do we adjust the secondary butterflies on a carb without secondary needles?
:cheers:
Old 07-02-2003, 06:45 PM   #8
WESCH
CF Senior Member
WESCH's Avatar
Hi
Ok, just got the confirmation from the previous owner of this carb.
It's been overhauled with a standard HOLLEY rebuild kit.
Thanks for all info.
Just an other question.
Will my Vette consume much more fuel with the 750 CFM carb ?
Thanks. Gunther :seeya
Old 07-02-2003, 06:48 PM   #9
WESCH
CF Senior Member
WESCH's Avatar
Default Re: paging Lars and all other carb gurus. (Boofers)
Hi Boofer
Quote:
Who is Gunther?
Gunther is me , the proud owner of a 68 Convertible with a beautifull big block, manual 4 gear M21 close ratio and crazy 3,70 rear end.
I still can't believe that driving something like this is allowed. :flag
Brgds Gunther
Old 07-02-2003, 06:52 PM   #10
Boofers
CF Senior Member
Boofers's Avatar
Oh I get it you're not saying thanks to Gunther you are saying thanks from Gunther... I need to take a nap.
your car = wow
Old 07-02-2003, 07:18 PM   #11
WESCH
CF Senior Member
WESCH's Avatar
Hi
Yes, me too. It's midnight over here now.
Good night. ( from ) Gunther :seeya
Old 07-03-2003, 02:29 PM   #12
lars
CF Senior Member
lars's Avatar
Default Re: paging Lars and all other carb gurus. (Lasse)
Lasse -
Holley carbs with 2-corner idle systems (no secondary needles) still discharge idle fuel through the secondary throttles: there are idle fuel transfer passages in the top surface of the throttle plate that transfer idle fuel from the primary side to the secondary side (they're curved passages that run down the right and left side of the throttle plate). Adjusting the idle mixture on the primary side affects the primary and secondary idle fuel equally. For this reason, the secondary idle should be set up even on 2-corner idle carbs in order to achieve best idle and best off-idle throttle response. Cracking the secondaries open equal with the primaries will assure that you will get the proper transition slot exposure for best carb performance.
Old 07-03-2003, 03:10 PM   #13
Lasse
CF Senior Member
Lasse's Avatar
Nice info Lars! I have read all kinds of Holley material, but hasn't found that sort of information :thumbs:
I have read that the transfer slot shall be exposed by 0.04" and sec trottels screw 'touch' plus 1/4 turn.
How do you measure when the pri/sec trootlles are equal?
Thanks Lars. :cheers:
Lars (aka Lasse)
Old 07-03-2003, 04:47 PM   #14
Lasse
CF Senior Member
Lasse's Avatar
Can I count turns on primary stop screw until it slightly touch (when the idle is set) and add sec stop screw turns (1/4 turn), divided it by two and set them equal to that amount?
Just a thought...
[Modified by Lasse, 9:48 PM 7/3/2003]
Old 07-04-2003, 01:46 AM   #15
lars
CF Senior Member
lars's Avatar
Lasse -
Set the primary throttle to expose .020" of the transfer slot as viewed from the bottom of the carb. At .020", the transfer slot will appear as a square hole (the slot is about .020" wide). Then, hold the carb up to a light and look up through the bottom of the carb: You will be able to see the "light gap" around the primary throttle blades. Adjust the secondary throttles to match the same "light gap." This will give you a nice, balanced setting with very good idle and throttle response.
Reload this Page paging Lars and all other carb gurus.
Tags
adjustments, holley, kit, r84013, r840131, rebuild
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
