Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-27-2003, 07:39 PM   #1
Ben Taylor
CF Senior Member
Ben Taylor's Avatar
Default 81 dual exhaust
I want to put dual exhaust on my 81 with a power driver's seat. Do I have to route both the exhaust pipes under the passenger seat like the stock setup, or is there a way to make straight pipes on both sides?
Ben Taylor is offline   Reply With Quote
Old 06-27-2003, 09:09 PM   #2
Dalannex
CF Senior Member
Dalannex's Avatar
Default Re: 81 dual exhaust (Ben Taylor)
I think you needs to run both pipes on the passenger side. i don't remember what it is, but seems to me there is something in the way on the driver side preventing it from running that way. Mine are both on the passenger side. For some reason the crossmember comes to mind.
-Justin
Dalannex is offline   Reply With Quote
Old 06-28-2003, 01:57 AM   #3
Glensgages
CF Senior Member
Glensgages's Avatar
Send a message via AIM to Glensgages
I was told that to provide more driver-side head room, driver-side seats are a bit 'lower', mandating all exhaust goes down passenger-side.Sounds plausible..... :confused:
Glensgages is offline   Reply With Quote
Old 06-28-2003, 02:00 AM   #4
BSeery
CF Senior Member
Arizona Events Coordinator
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10
BSeery's Avatar
Location: Exiled to Richmond, VA - anyone want to buy a house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
Send a message via AIM to BSeery Send a message via Yahoo to BSeery
Default Re: 81 dual exhaust (Dalannex)
-Justin
Yes, 1980 - 82 the crossmember only has 1 place to route exhaust, and that is on the passenger side. The only other solution is to cobble a pre-1980 crossmember into place like I did. They are not a direct bolt in.
BSeery is offline   Reply With Quote
Old 06-28-2003, 02:02 AM   #5
BSeery
CF Senior Member
CI 6-7-8 Veteran
BSeery's Avatar
Default Re: 81 dual exhaust (Glensgages)
No, they just changed to a MUCH lighter crossmember and only allowed one place to route the exhaust. Not much care by GM since they were only building 3 model years like this and couldn't do duals anyway.
The exhaust is actually pretty close to the transmission tunnel and almost against the trans on mine and does not go under the seat.
Old 06-28-2003, 02:09 AM   #6
Glensgages
CF Senior Member
Glensgages's Avatar
Default Re: 81 dual exhaust (BSeery)
Thanks, BSeery. I recently saw an '82 C.E. on a lift after getting true-duals (2.5", no cat OR mufflers for $150.00!!!). The owner told me of the 'low-seat' theory. On this car, it DID look as if driver's-side floor-pan was lower than passenger-side. I guess I 'bought' it....
Old 06-28-2003, 04:30 AM   #7
Hemmo
Junior Member
Hemmo's Avatar
And No again, driver-side seat doesn't sit lower but the motor and bracket take more room than passenger-side so the floor pan is deeper and comes in way when you are installing duals. Don't know about crossmember since I don't have stock one.
I have duals installed and only problem is that driver-side pipe touches the pan. That I deal with little heat barrier installed between them, it also prevents pipe hitting the pan on idle as it's vibrating.
Hemmo is offline   Reply With Quote
Old 07-05-2003, 02:18 AM   #8
vettesite
CF Senior Member
vettesite's Avatar
I have 2.5" true duals, no cats, H pipe, and headers on my 1980. No seat clearance issues. Just get a dual hole automatic frame cross member from a 1979 or older. It bolts on with some modification. You will also need the perch (mounting bracket) that the trans sits on that bolts to the cross member. I have a dual hole cross member (no perch) if you are interested, webmaster@vettesite.com
Here is a pic:
http://www.vettesite.com/1980vette.asp?mypage=exhaust
[Modified by vettesite, 12:22 AM 7/5/2003]
vettesite is offline   Reply With Quote
Old 07-05-2003, 10:18 AM   #9
914eener
CF Senior Member
914eener's Avatar
Save yourself some hassle...buy the true dual kit from MAD. Mine fit like a glove.
914eener is offline   Reply With Quote
Reload this Page 81 dual exhaust
Tags
81, corvette, dual, exhaust
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Performance Headers & True Dual Exhaust Legal for an 81? 81 4spd Scooter C3 Tech/Performance 13 04-24-2005 11:17 AM
Dual exhaust for my 81 my2crazyeyes C3 Tech/Performance 16 05-20-2003 10:54 AM
Dual Exhaust ??? mvftw C3 Tech/Performance 9 05-04-2003 11:00 PM
True dual exhaust for an 81 jaybird81 C3 Tech/Performance 10 09-11-2002 08:20 AM
True Dual Exhaust? Kloppy80 C3 Tech/Performance 13 01-26-2002 10:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
