LINE LOCKS ARE COOL!!!
Check out the 1/4 " hole I dug in the pavement
[Modified by 69 N.O.X. RATT, 6:02 AM 6/27/2003]
Re: LINE LOCKS ARE COOL!!! (69 N.O.X. RATT)
Darn it I can get the pic on my sig but not the forum. Any suggestions?
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
http://us.f1.yahoofs.com/users/65d9d...ip8..AIuzwgpvx
bad link of dead file name
[Modified by BSeery, 10:57 PM 6/26/2003]
I see the picture in my profile. I am still trying to figure out how to post it. Can anyone else see it in my profile.
[Modified by 69 N.O.X. RATT, 1:21 PM 6/27/2003]
E-mail me the picture and I'll post it.
Linelocks are awsome!!! :D :D
Just click below to see a nice video :D :D :D
Click here
[Modified by GrandSportC3, 10:36 AM 6/27/2003]
Click here
Re: LINE LOCKS ARE COOL!!! (Mystery Machine)
A line lock (or roll control as they're sometime called) consists of an electrical solenoid that's plumbed into the brake system downstream from the proportioning valve or distribution block or pressure differential switch.
Once it's installed you hit and hold the brake pedal, press and hold a button in the cockpit and then release the pedal. At that point the brakes on the side of the brake system with the line lock installed are locked, but the others aren't.
They are commonly installed on the front brakes of a car for drag racing. Lock the front wheels and then do your burnout with the rears. This way you don't wear our your rear brake pads doing what you call a brake stand in the burnout box--you just let go of the button and the front brakes release and off you go.
You could install TWO line locks in your drag car to lock all four brakes to hold you at the starting line while you bring the RPMs up. Then, of course you would launch the car by simultaneously releasing the line lock button and stabbing the throttle. (Sort of a poor man's trans brake.)
You can also use a line lock on a tow vehicle or RV to hold you on hills, etc.
Pretty useful little gadgets, really.
[EDIT: For typos.]
[Modified by The Dude, 9:18 AM 6/27/2003]
[EDIT: For typos.]
Re: LINE LOCKS ARE COOL!!! (isosceles)
Are you coming to the Corvette Challenge tomorrow???
