choke light keeps flickering while driving
2nd Gear
im new to corvettes, just bought my first one a 80 L-82 and while driving my choke light on the dash flickers on and off and there is a buzzer that makes noise while the light flickers also , drives me crazy , any help?? and there seems to be a little left to right play in the steering wheel while driving, it does need new tires and im sure a front end alignment, but i thought you might have other suggestions? thanks for any help
Re: choke light keeps flickering while driving (rick s)
choke light? hhhmmm...
i dont have one oof those...
as far as the sloppy steering goes, i will wait and see what others here say cause most of the guys here know what my answer would be... STEEROIDS :lol:
On my 81, the choke lite works on more than just the choke. I couldn't pass smog with the choke lite on, so it had to be fixed. Can you run the diagnostics by the ashtray? :flag
I looked up your vette's year, an '80.
Most likely cause I've found on this:
Check your alternator connections (and ground). If OK, check the alt output.
Good Luck -Rod :chevy
Re: choke light keeps flickering while driving (ROD NOCK)
Just fixed one last week, doing the exact same thing and it was the brown wire on the Alternator. Was broken at the plug.
