Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-16-2003, 10:48 AM   #1
1974slcvette
CF Senior Member
1974slcvette's Avatar
Default Help w/ engine identification
Good morning everyone!! I have a question regarding my engine. I have searched high and low, and cannot seem to find any reference for the engine i.d. on the front of my block. I know it is a 350 (GM casting # 14016379), but the number on the front is: VK 202800. I think it may be a replacement or crate engine, but any feedback would be greatly appreciated. This is NOM in my 1974.
1974slcvette is offline   Reply With Quote
Old 06-16-2003, 02:07 PM   #2
no_radio
CF Senior Member
Default Re: Help w/ engine identification (1974slcvette)
crud, my engine book is at home so I can't help unless I get online tonight at the house...but I'll bump it to the top...
Jeff
no_radio is offline   Reply With Quote
Old 06-16-2003, 02:28 PM   #3
1974slcvette
CF Senior Member
Default Re: Help w/ engine identification (no_radio)
I have checked the "Cherolet by the Numbers" book, and it is not listed. The block dosen't have any suffix code...
Old 06-16-2003, 02:48 PM   #4
topless68
CF Senior Member
topless68's Avatar
Location: Your Fighting Tigers of LSU. 2003 National Champs
14016379 is '78-'79 passenger car and light truck 350.
I do not have the proper book in front of me to decipher the VK...
[Modified by topless68, 12:49 PM 6/16/2003]
topless68 is offline   Reply With Quote
Old 06-16-2003, 02:50 PM   #5
Tom73
CF Senior Member
Tom73's Avatar
Quote:
...reference for the engine i.d. on the front of my block. I know it is a 350 (GM casting # 14016379), but the number on the front is: VK 202800.
The casting #, 14016379, is for a 77-79 350. Assume that the VK 202800 is on the stamp pad (machined surface on the block in front of the passanger side head). Should be two sets of numbers stamped there. Second set would be something like V0217CLK. With that second set of #'s should be able to identify the engine.
tom...
Tom73 is offline   Reply With Quote
Old 06-16-2003, 03:21 PM   #6
crm711
Junior Member
crm711's Avatar
Default Re: Help w/ engine identification (Tom73)
Check out http://www.nastyz28.com. See if that gives you the info you are looking for.
crm711 is offline   Reply With Quote
Old 06-16-2003, 04:18 PM   #7
1974slcvette
CF Senior Member
VK 202800 is the only number stamped on the front pad... No VIN, or any other number for that matter. I'm perplexed... From the posts that I've read the engine is fron 77' - 79', but the date stamp on the block is: J 13 2. Which means the engine was manufactured in 72', 82', 92'... Seems the more research I do, the more confusing it gets. :confused:
Old 06-16-2003, 05:27 PM   #8
Tom73
CF Senior Member
Tom73's Avatar
Could be that the VK 202800 is just a stamp that the engine rebuilder used to id the engines.
tom...
Old 06-16-2003, 05:48 PM   #9
1974slcvette
CF Senior Member
I hadn't thought of that Tom, good call. A machine shop could have wiped out the original!! :thumbs:
Reload this Page Help w/ engine identification
Tags
14016379, 74, block, casting, chevy, corvette, engine, id, idenification, identification, locate, number, numbers, nunber, online
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
