New forum member.
New forum member.
Hi Guys,
Well just landed on your mailing list. I live in the Dominican Republic and am the proud owner of a 68' 427 convertible vette. The car is in the middle of a frame off restoration and it's worked by myself over the weekends.
At this moment, the frame is to 90 % ready. All parts were sandblasted and semi gloss black spray painted.
It has all new polyurethane bushings, front and rear spindles and brake covers chromed, all new seals and bearings, Power Slot brake rotors and Ferro Carbon brake pads, VBP suspension kit from Eckler's with Bilstein Shocks ,new front coil springs and rear fiberglass spring, 1 1/8 front and 3/4 rear sway bars.
New fuel tank with stainless steel lines, new power brakes stainless steel lines, new brake hoses, all rebuilt callipers. The rear end is also ready and rebuilt it has 355 gears installed instead of the 411 which the car had when purchased. 4 speed Muncie M21 Manual transmission also freshly rebuilt (last weekend).
The engine is a 427 four bolt main, 2.2" intake valves, 1.96" exhaust valves, double valve springs, 3 angle valve job, Action Plus intake manifold, Holley double pumper 750 cfm, Standard crank, Isky Mega Cam & Lifters, Cloyes True Double Roller Timing Chain Set, Torrington Block Saver Roller Bearing Set, Melling High Volume High Pressure Oil Pump with a Welded on Oil Pick Up Screen, A Melling Steel Sleeved High Performance Drive shaft, Roller Tip Rocker Arms, 3/8" Push Rods & Guide Plates, GM High Performance Connecting Rods, Hypereutectic Pistons, Closed gap rings etc.
Well as soon as I have some time I'll start building my homepage and write all the stories during the restoration.
So long for now,
Dan
So long for now,
Dan
Re: New forum member. (Daniels)
Sounds like you are going to have a first class set up Dan. Good luck with the vette and keep us updated. Oh yeah, welcome to the forum.
1 Post
St. Jude Donor '09
Re: New forum member. (Corey 68)
Sounds like you have it all planned out already...
Welcome to the Corvette Forum.
Hope you can make it to some of the get togethers... :lol: :lol: :lol:
Just like the guys in Hawaii.... :thumbs:
Re: New forum member. (81' Corvette Guy)
Welcome to the forum,sounds like your gone to have one sweet vette when your done,good luck,any pics of whats done so far?
Re: New forum member. (patsnitrovette)
Got lot's of pic of every weekend I've worked on the car. As soon as I have a little time, I'd like to build my homepage. How do you post pics on the forum?
1 Post
welcome! :seeya '
About the pics; you need to find a place that will host them. Many ISP's give free web space for pages and such, pics can be hosted there as well. The hosting here has not been available to new members signing up for a while. I joined last August and don't have permissions. With server space limited, I'll bet it was granted first come first serve.
