What could make your gas turn green?
Old 05-28-2003, 11:19 AM
Black'69
Black'69's Avatar
Default What could make your gas turn green?
Hey Guys,
This is a follow up to my green goo in my carb question. After looking into my gas tank, (with an FM approved flashlight, no matches) I can see that the gas it self has a greenish tint to it. I have been mixing 76 100-octane racing gas with 76 91-octane during fillups. The car did sit for about 2 months, but I didn't think that was enough time for it to get funky. If I look inside my intake with the carb off, it looks like there's a green gum coating the inside. I hit it with some carb cleaner and it dissolved fairly easily.
So the questions are:
1. What the heck caused my gas to turn green?
2. Should I drain the entire system or is it ok to burn?
3. If I do have to drain the tank, where can I get rid of 15 gallons of gas?
Thanks in advance for any tips,
Christ
Old 05-28-2003, 11:23 AM
Paul Borowski
Support Corvetteforum!
Paul Borowski's Avatar
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: What could make your gas turn green? (Black'69)
I've seen Dry Gas, which emulsifies water in gas turn green. Used any of that stuff lately???
Old 05-28-2003, 11:27 AM
Black'69
Black'69's Avatar
I haven't put in any additives other than the 100 octane gas. Could someone have dumped something in my tank trying to mess with the car?
Christ
Old 05-28-2003, 12:17 PM
wcsinx
wcsinx's Avatar
The only green gas I've ever seen was the ag(ricultural) gas that my dad used to put in all the farm implements. You haven't been siphoning from the tractor tank have you? It's actually illegal to put that stuff in a car.
Old 05-28-2003, 12:57 PM
redvetracr
redvetracr's Avatar
"aliens" sorry I couldn`t resist!!
...redvetracr
Old 05-28-2003, 12:59 PM
Tom73
Tom73's Avatar
...and St Patricks Day has already passed.... :thumbs:
Old 05-28-2003, 01:08 PM
77Dream
77Dream's Avatar
If I sat for two months i'd turn green too :D Maybe the racing gas doesn't have the "shelf life" of regular gas. Thats all I can think of.
Old 05-28-2003, 02:03 PM
pws69
pws69's Avatar
Hulk p!ssin' in your gas tank???
Old 05-28-2003, 02:42 PM
e3pres
e3pres's Avatar
You might try giving them a call:
https://www.76.com/cgi-bin/b2cpt01/scripts/contact.jsp?BV_SessionID=@@@@0318320623. 1054145460@@@@&BV_EngineID=ccchadcihdkgh mmcfimcemndhhgdgjg.0&Site=76&Nav=contact &Cat=contact&contentType=contact
Old 05-28-2003, 05:58 PM
bb69
bb69's Avatar
Default Re: What could make your gas turn green? (e3pres)
Gas will turn green is a short time under the right conditions. My guess is that not only is it green, it probably smells pretty bad. I just had to completely clean our a lawnmower carb to get rid of the green sludge. My garage stills smells several days later. I would drain the gas into some gas cans, and use it in a lawnmower or other small engine if you have them. Just make sure whatever it is, you're going to use it quickly. Putting in fresh gas should help get rid of the green mess. If the car won't start, you need to clean the carb. The green stuff loves to clog jets. Good luck.
Old 05-28-2003, 06:00 PM
Black'69
Black'69's Avatar
Called 76 like e3pres suggested, think I have the answer.
The green issues is most likey caused by the mixing of the 100-octane and 91-octane. 91 has a yellowish straw color as where the 100 has a blue dye added to it. Apparently it's being sold under the name cool blue at speed shops. Oh course, as I learned in pre-school, yellow and blue make green.
The gumming issue is most likey caused by the EPA mandate to remove MBTE from gas. The replacement, ethonal, is alcohol based and acts as a good cleaning agent, thus puling all the crap out of the tank and pushing it through the line to the carb. They mentioned that this might be a problem for older cars when making the switch to the ethonal based gas.
The 100 octane is the only one still with MBTE, so when I mixed with the 91 the ethonal started doing it's business.
As of Jan 1st next year all gas should be ethonal based, so keep an eye out for gum and deposits at least for the first few tanks.
At least I know it wasn't the Hulk taking a leak in the tank.
Thanks for the help guys,
Christ
Old 05-28-2003, 06:09 PM
77Dream
77Dream's Avatar
Hmmm.. Thats good to know, thanks. :thumbs:
To What could make your gas turn green?
Quick Reply: What could make your gas turn green?
