need for speed
Old 05-28-2003, 12:53 AM
82coupe
Cruising
82coupe's Avatar
Default need for speed
My 82 coupe's engine has been rebuilt to original specifications including the crossfire injection. How can I get more power and maintain some degree of original specs. What about underdrive pulleys, proformance chips, Ignition modules to increase dwell,throttle proformance switches.How about true dual exhaust, I should be able to add another catalytic converter for the second pipe.
Old 05-28-2003, 01:04 AM
battsup
battsup's Avatar
Default Re: need for speed (82coupe)
Exhaust and a camshaft will give you the most bang for the buck, but if what your looking for is a seat of the pants experience and dont mind a little bit poorer gas mileage then you could replace the rear gears with 3.73s. I personally wouldnt reccomend anything higher(4.11s,etc) because of the gear noise at high speeds
Old 05-28-2003, 01:09 AM
tnt76vette
tnt76vette's Avatar
Default Re: need for speed (battsup)
Trual Duals, with or w/o Cats, depending on your states emission laws, will give you a definite Kick in the A, and help your mileage in the process....... :yesnod: :yesnod: :yesnod:
Old 05-28-2003, 04:42 AM
Desertdawg
Desertdawg's Avatar
St. Jude Donor '09
Hi Mark. and welcome the the Corvette Forum :seeya
One of the greatest corssfire tuners lives in your backyard. Ken73. Him and Marck (Twin Turbo) have another forum set up for us...
http://www.crossfire.homeip.net:81/
You can find tons of info about the crossfire there...And plenty of hop up info too....
Take a look, but don't forget to come back here too...this place is great. :thumbs:
To need for speed
Quick Reply: need for speed
