New fuel line - Check it out.
I was running the metal/flexible line/hose clamp set up. Talked to Paul at http://www.hydroboost.com/. He hooked me up with the same material that he makes linesets out of. Got a good looking, secure fuel line for the Demon now.
Senior Member since 1492
Re: New fuel line - Check it out. (dman535)
Nice setup. I like it. Looks like SS Braided. :thumbs:
Re: New fuel line - Check it out. (1970 Stingray)
Hey, my braided fuel line from Summit showed up in the brown truck yesterday. I'm going to put in on tomorrow. Should I use teflon tape on the aluminum fittings? I've never delt with these things before.
Re: New fuel line - Check it out. (Scooter70)
If you use the tape, don't wrap it on the first two threads. :nono:
No tape. But you might need new steel crush washers that go in between the fittings and the float bowl. Demon sent a set to me free of charge when the repaired a messed up helicoil in the carb body.
Re: New fuel line - Check it out. (Alwyn678)
They make tape for gas, it is yellow and stays in one piece on the line :D
