Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-06-2003, 10:24 PM   #1
mcfly5
Junior Member
Default need some help with my '79 L82....runs rough
i know...."runs rough" could be lots of things....but i've replaced the following: plugs, wires, rotor, cap, pcv, fuel filter, rear seal, air filter. firing order is correct, vacuum lines are correct. all the emissions stuff has been removed. the car ran great, so i've never touched any of the carb settings. i start it, it never really idles well. it just kind of lopes; everything is stock. any ideas?
help!! the weather is getting nice!!
thanks
mcfly5 is offline   Reply With Quote
Old 05-06-2003, 10:30 PM   #2
dman535
CF Senior Member
dman535's Avatar
Default Re: need some help with my '79 L82....runs rough (mcfly5)
where is your timing ? You try advancing it ?
dman535 is offline   Reply With Quote
Old 05-06-2003, 10:30 PM   #3
Jvette73
CF Senior Member
Jvette73's Avatar
Have you done a compression check? This would tel you the general condition of the engine mechanical. For instance you may have a burnt exhaust valve or blown head gasket between two cylinders. These failures would show up in a compression test.
Jvette73 is offline   Reply With Quote
Old 05-06-2003, 10:30 PM   #4
joeveto
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
joeveto's Avatar
Have you checked the idle mixture? You said the vacuum hoses are fine, but what is the reading? Is your air filter on tight?
What's your timing at? Have you checked this? Your initial should be at 10-12 BTDC w/o the vacuum advance.
Do you have the stock cam? If you have a heavy aftermarket cam, you would naturally have a "lopey" idle. Different from a rough idle.
Just a few suggestions.
joeveto is offline   Reply With Quote
Old 05-06-2003, 10:39 PM   #5
Jvette73
CF Senior Member
Jvette73's Avatar
Default Re: need some help with my '79 L82....runs rough (Jvette73)
Also could be worn timing chain stretched , or jumped a tooth causing late valve timing and low compression. How many miles on the engine?
Old 05-07-2003, 05:58 AM   #6
paul 74
Ontario, Canada
Support Corvetteforum!
paul 74's Avatar
If it lopes at idle but doesn't stall, then that is simply the L-82 cam at work.
paul 74 is offline   Reply With Quote
Old 05-07-2003, 08:55 AM   #7
page62
CF Senior Member
page62's Avatar
Mine's lopey at idle, too. The L82 cam has a lot to do with it, but there could also be a vacuum leak -- carb base or intake manifold gasket are two suspects.
I got this tech tip last night: Spray carb cleaner slowly around the areas you want to test. If the engine increases in rpm as you spray a certain area, you've found a vacuum leak. :yesnod:
page62 is offline   Reply With Quote
Old 05-07-2003, 12:08 PM   #8
groovyjay
CF Senior Member
groovyjay's Avatar
Have you checked the vacuum lines? :cheers:
groovyjay is online now   Reply With Quote
Old 05-07-2003, 12:22 PM   #9
DaveL82
CF Senior Member
DaveL82's Avatar
Default Re: need some help with my '79 L82....runs rough (groovyjay)
Does it run Ok when it is cold, then gets worse as the enigine reaches full temp? It so this is also a sign that the HEI module is bad. Usually they do not show stumble/hesitation until the throttle begins to open (can't fire the richer mixture).
DaveL82 is offline   Reply With Quote
Old 05-07-2003, 04:40 PM   #10
john's '81 mouse
CF Senior Member
john's '81 mouse's Avatar
Default Re: need some help with my '79 L82....runs rough (DaveL82)
Quote: "Does it run Ok when it is cold, then gets worse as the enigine reaches full temp? It so this is also a sign that the HEI module is bad. Usually they do not show stumble/hesitation until the throttle begins to open (can't fire the richer mixture)."
Sorry, but I've got to take exception to what you're saying........the 'mixture' is richer when the engine is cold, and then leans out as the choke comes off as the engine warms up. Believe malfunction of ignition model is more often due to presence of heat.........as the model becomes hotter, it begins to malfunction, much like a bad coil will do. Having said that, I belive this particular problem is more likely attributable to an air/fuel/vacuum problem, or engine timing is too slow (not advanced far enough) for some reason .
john's '81 mouse is offline   Reply With Quote
Old 05-07-2003, 05:50 PM   #11
killain
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Oldtimer
killain's Avatar
Send a message via AIM to killain
If you've hooked up a vacume gauge to it it should draw about 19 inches of vacume. I'd say if it ran good before and the lopy idle is a new condition it somewhere in you carb. The L-82 is a little rougher than the L-48? Put everything back to stock settings and see if it dosent clear up, if not look at your carb for the problem. :bb
killain is offline   Reply With Quote
Old 05-07-2003, 06:51 PM   #12
DaveL82
CF Senior Member
DaveL82's Avatar
Default Re: need some help with my '79 L82....runs rough (killain)
Johns 81 - you take take exception with no problem and this may not be the cause. I've had 6 fail over the last 20 years. The engine runs fine cold, the the module gets hot, this then causes the car to bog/run rough when you put your foot on the gas (richer mixture). Idle and part throttle crusie are usually fine when the module fails. However this could be an exception to the normal failure mode and may be worth a try.
Old 05-09-2003, 05:48 AM   #13
jubee
Junior Member
I've been having the same problem. Do a search under my user id and see the posts I've been chasing. I still ahven't figured mine out. I'm doing another compresion check tomorrow just to be safe.
Joe
jubee is offline   Reply With Quote
Old 05-09-2003, 08:12 AM   #14
Rich80
CF Senior Member
Rich80's Avatar
Mine lopes when i first start it up. Always did that. I know its a vacuum leak somewhere. Once it warms up shes fine.... :smash:
Rich80 is offline   Reply With Quote
Reload this Page need some help with my '79 L82....runs rough
Tags
1979, 79, c3, corvette, filter, fuel, hot, idle, idles, l82, location, prob, rough, running, warm
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
