Pictures from couple of car shows in Finland. Including -68 BiTurbo vert. (dial-ups be aware...)
Some are pics and some are only links, just to make this at least a bit easier for dial up users...
American Car Show in Helsinki (18th-21st of April).
Nice C1 from Germany
Great looking -72 454cid.
Another nice -72... Big block hood is badges as L-82... :smash:
Very nice BB -73, not #'s matching though.
Another C3, -76 coupe...
Same car, another angle...
http://temp.corvetteforum.net/c3/fin...s-76-l48-2.jpg
C3 race car...
http://temp.corvetteforum.net/c3/finnshark//acsdrag.jpg
Parking lot is also great place to find some cool cars...
http://temp.corvetteforum.net/c3/fin...//acspark1.jpg
http://temp.corvetteforum.net/c3/fin...//acspark2.jpg
http://temp.corvetteforum.net/c3/fin...//acspark3.jpg
http://temp.corvetteforum.net/c3/fin...//acspark4.jpg
http://temp.corvetteforum.net/c3/fin...//acspark5.jpg
http://temp.corvetteforum.net/c3/fin...//acspark6.jpg
Hot Rod & Rock Show in Tampere (26th and 27th of April).
Personally I don't like this colour, but it is great show stopper anyway...
Nice -62...
http://temp.corvetteforum.net/c3/finnshark//hot3.jpg
Red -76 coupe...
http://temp.corvetteforum.net/c3/finnshark//hot4.jpg
This C4 was exported to Finland when new. Last C4 exported by the GM Finland...
http://temp.corvetteforum.net/c3/finnshark//hot5.jpg
This car desrves many pics! -68 vert powered by 454 and two turbos... Great looking ride!
http://temp.corvetteforum.net/c3/finnshark//hot7.jpg
http://temp.corvetteforum.net/c3/finnshark//hot10.jpg
http://temp.corvetteforum.net/c3/finnshark//hot11.jpg
Thanks for your attention! :cheers:
[Modified by FinnShark, 12:42 PM 5/5/2003]
C3 race car...
Nice -62...
Red -76 coupe...
Re: Pictures from couple of car shows in Finland. Including -68 BiTurbo vert. (FinnShark)
Those are awesome! Sweet cars...even the ones in the parking lot! :thumbs: That blue '68 TT is pretty wild! I love the paint!
Thanks so much for sharing those. You guys have some beautiful vettes over there! :yesnod:
Re: Pictures from couple of car shows in Finland. Including -68 BiTurbo vert. (patsnitrovette)
the twin turbo has C4 suspension!!!
I love it :)
I found some more on their page: http://www.rmotorsport.com
[Modified by Twin_Turbo, 6:51 AM 5/5/2003]
I love it :)
Thanks for posting the pics Riku, I missed both shows this year.
That 68 is pretty amazing considering our regulations, wonder how easy it is to get pass the annual inspection??
rgds Tomi
rgds Tomi
Wow, nice set of pics. I especially like the way the first one turned out. How did you get it to look like that?
Re: Pictures from couple of car shows in Finland. Including -68 BiTurbo vert. (Twin_Turbo)
Twin_Turbo: Nice catch! I didn't even notice that there was C4 suspension... I was so thrilled about the engine that the suspension was left out...
Tomi72: Too bad that you missed the shows... I wouldn't be so worried about the annual inspection, but the inspection where you qualify the modifications might be interesting...
Eddie 70: I like the first pic too. It came out pretty nicely... Tripod and long exposure time makes nice effects... You can see same effect in other pics too. Somehow the first one seems to be kind of unreal, even though I haven't modified the pic at all...
[Modified by FinnShark, 3:58 PM 5/5/2003]
I wish I could see that car up close, I'd photograph everyy inch of it :)
Did you notice they used the C4 engine cradle/suspension corssmember? In the C4, that's a 1 piece bolt on thing. they modifed it and welded it on the frame, yet retained the stock C3 motor mounts. They must have cut the mounts off the C4 cradle.
It's bolted to the frame, not welded. C4 mounts have been cutted.
The car was also at American Car Show in Oulu 3-4.5.2003, with an mod list. I try to post it:
Engine
Base engine 454 LS-6
Twinturbos by LDS-Racing turbo
Haltec Programmable engine management system
750cc custom made injectors
Stainless steel exhaust manifold
Stainless steel 3,5/3 " exhaust system
Waste gates by Pate Racing
Blow-off valves by Pate Racing
2pc Bosch high pressure fuel pumps
Edelbrock Victor-R intake modified for EFI
Billet throttle body by PO-Metal
Intercooler by Roni
Lunati roller cam
Stainless steel valves, 15deg Valve Locks
Roller rocker arms
Custom under drive pulleys with crank sensor
Modified location and attachment
Front axle
Corvette C4 axle
Composite spring
Aluminum upper & lower A-arms
Aluminum wheel spindles with ABS sensors
Bilstein shocks (custom made race shocks)
30mm sway bar
Rack and pinion steering, 2.0 turns lock to lock, PS removed
11,5" brakes with Corvette aluminium calipers (4-piston race brakes)
Z-51 spec bushings, steering, spring rates, shocks
17" wheels with 255/40 Goodyear F1 tires
Rear axle
Modified Corvette -68 axle
Limited slip differential with 3.37 gears
Modified differential location, attachment and suspension geometry
3.5" aluminium drive shafts
22mm sway bar with heim joints and nylon bushing
Composite spring with height adjustments
11,75" brakes with Corvette 4-piston calipers (4-piston race brakes)
Polyurethane bushings at trailing arm
Adjustable strut rods with heim joints by VBB
Power train
A1 custom-made torque converter
Modified TH 350 semi-automatic
3" custom made drive shaft
Hurst shifter
Body
-68 Corvette cab
14-point roll bar
Removable convertible top
Custom lightweight deck lid
Remounted firewall
C4 aluminium pedal system w/o brake booster
5-point 3" safety belts
New electricity; wires, all relays
Special mounted generator
Custom seats
Estimated weight: 1350kg w/o driver
Performance
Not tested yet
Estimated engine power for street use: 500hp/800Nm
Estimated engine power for race use: 700-1100hp/1000-1500Nm
These old figures are without EFI and turbos:
0-100km/h 3.2s
0-200km/h 11.4s
100-200km/h 8.2s
1/4 mile 11.079s 198km/h
Re: Pictures from couple of car shows in Finland. Including -68 BiTurbo vert. (SakuR)
Engine
Intercooler by Roni
Lunati roller cam
Roller rocker arms
Front axle
Corvette C4 axle
Composite spring
30mm sway bar
Rear axle
Power train
Hurst shifter
Body
-68 Corvette cab
14-point roll bar
Remounted firewall
Custom seats
Performance
Not tested yet
0-100km/h 3.2s
0-200km/h 11.4s
100-200km/h 8.2s
Engine
Intercooler by Roni
Lunati roller cam
Roller rocker arms
Front axle
Corvette C4 axle
Composite spring
30mm sway bar
Rear axle
Power train
Hurst shifter
Body
-68 Corvette cab
14-point roll bar
Remounted firewall
Custom seats
Performance
Not tested yet
0-100km/h 3.2s
0-200km/h 11.4s
100-200km/h 8.2s
[Modified by Twin_Turbo, 5:21 AM 5/6/2003]
SakuR: Great to have you here! Welcome! :cheers:
Maybe you can give us some more detail pics about your project? Too bad that I didn't met you at the show. I was at another stand and didn't have time to come and say hello to you. You weren't there at the time I was taking the pics...
Your project is really impressive! When do you think your car will be in the streets? It would be great to see your car and Groovyjays -79 BB EFI in the same place at the same time! :cool:
1 Post
St. Jude Donor '09
Re: Pictures from couple of car shows in Finland. Including -68 BiTurbo vert. (Mystery Machine)
I just can't get over the color of this C3 WOW !!! :eek:
The blue twin turbo is AWESOME! Thanks for sharing the pics. :thumbs:
Thanks, here is a couple of more pics:
There are around 50 points in my notebook what has to be done before driving. Guess it takes at least a month. I'll try to make it to the Forssa Pick Nick anyway and maybe some track or drag race events or Vette club meetings.
I love it :) do you have some more pics of that engine /suspension cradle ? It's kind of hard to see here because everything is blue :)
