My 383 is finally progressing.............(lots of pics)
Location: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
It might be done for next weekend, I'm planning on getting it dyno'd before installing it.
Without further adou................here are the pic's
:hurray: :party: :D :chevy
[Modified by 69shark, 10:21 PM 5/5/2003]
Re: My 383 is finally progressing.............(lots of pics) (69shark)
Looks like it should be very nice. I missed all the details on it. What all is going in there? I kind of wish I would have went ahead and went 383 too. Good luck with the build up and keep us posted with the results.
St. Jude Contributor
Kudos for taking all the spiffy pics and posting them. Amazing how beautiful pistons, valves, blocks and heads can look before they are detonated with gasoline fumes & the lead foot that will attempt to see how far it can go through the floorboard.
Cruise-In I Veteran
Re: My 383 is finally progressing.............(lots of pics) (79Corvette02)
Thanks guys :cheers:
As for the specs:
Eagle 383 Stroker kit(included - crank, rods pistons/pins)
Pro Topline Aluminium Heads
Manley Valves and Springs
Crower Stainless 1.6 Roller Rockers
Crane Hydraulic Roller Cam #119831 updated below
Weiand Alumium Water Pump
MSD Billet Tach Drive Distributor
MSD 6AL
Moroso Oil Pan(high capacity{7qts})
Edelbrock 2 Piece Aluminium Timing Cover
Chevrolet Aluminium "Corvette" Valve Covers
Edelbrock Performer Intake manifold
Dynomax Ceramic Coated Headers
Hurst Competion Plus Shifter
Dewitts Dual 11" Spal Electric Fan Kit
:chevy :chevy :chevy :chevy :chevy :chevy :D
Crane Camshaft Specification Card
Part Number: 119831
Grind Number: HR-284-2S-12 IG
Engine Ident: 1957-1987 CHEVROLET V-8 262 THRU 400 CU.IN.
WITH CAST IRON DISTRIBUTOR DRIVE GEAR.
VALVE SETTING: INTAKE .000 EXHAUST .000 ----> HOT
LIFT: INTAKE @CAM 339 @VALVE 509 ROCKER ARM RATIO
EXHAUST @CAM 352 @VALVE 528 1.50
ALL LIFTS ARE BASED ON ZERO LASH AND THEORETICAL ROCKER ARM RATIOS
CAM TIMING OPENS CLOSES ADV DURATION
@ .004 INTAKE 31.0 BTDC 73.0 ABDC 284.0 °
TAPPET LIFT EXHAUST 79.0 BBDC 33.0 ATDC 292.0 °
SPRING REQUIREMENTS
TRIPLE DUAL OUTER INNER
PART NUMBER 99838
LOADS:
CLOSED 110 LBS @ 1.688 OR 1 11/16
OPEN 330 LBS @ 1.188
RECOMMENDED RPM
RANGE WITH MATCHING COMPONENTS
MINIMUM RPM 2500
MAXIMUM RPM 6000
VALVE FLOAT 6500
CAM TIMING OPENS CLOSES MAX LIFT DURATION
@ .050 INTAKE 4.0 BTDC 38.0 ABDC 107 °ATDC 222.0 °
TAPPET LIFT EXHAUST 52.0 BBDC (2.0) BTDC 117 °BTDC 230.0 °
[Modified by 69shark, 10:14 PM 5/5/2003]
As for the specs:
MSD 6AL
Part Number: 119831
SPRING REQUIREMENTS
PART NUMBER 99838
LOADS:
RECOMMENDED RPM
MINIMUM RPM 2500
MAXIMUM RPM 6000
VALVE FLOAT 6500
:cool: :cool: :cool:
Motors are so pretty! :) what cc are the intakes and what are the valve size?
Looks like we have similar taste...I would post a pic or two of my motor on the stand...but I haven't put them on the web yet. We "dry" fitted the motor in the car Friday. The Moroso badge on the oil pan is highly visible from the top view...
Cruise-In IV Veteran
Re: My 383 is finally progressing.............(lots of pics) (MGSFJET)
damnit Tom........ now i gotta step up to the plate..
looks good :thumbs:
I'll be looking forward to lining up with you later this year :steering:
looks good :thumbs:
Cruise-In I Veteran
Re: My 383 is finally progressing.............(lots of pics) (gkull)
Cruise-In I Veteran
Re: My 383 is finally progressing.............(lots of pics) (Corzvette69)
looks good :thumbs:
looks good :thumbs:
