Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-18-2003, 11:46 PM   #1
ORVette
CF Senior Member
ORVette's Avatar
Default Any TH400 experts? Trans. pump whining like crazy...and more!
I noticed my trans was having some trouble shifting into 3rd gear. It just sort of held 2nd, even at part throttle, then just kind of slid over into 3rd. Today, it wouldn't even slide into 3rd, just stayed in second until I let off, then felt like I pushed the clutch in, and had to rev up in second to get it to go again. Plus, it was starting out in second after coming to a stop unless I manually shifted it into low. In addition to all this, the pump is whining like crazy when I get above a couple thousand RPM. I tried adjusting the modulator up and down. I pulled the pan to check if my valve body bolts were loose, and there were a couple pretty good size metal shavings in the pan, along with a lot of metal "dust". Is it time for a new trans? :sad:
ORVette is offline   Reply With Quote
Old 04-19-2003, 01:08 AM   #2
427Hotrod
CF Senior Member
427Hotrod's Avatar
Default Re: Any TH400 experts? Trans. pump whining like crazy...and more! (ORVette)
Sounds like pump is toast. How long has it been since you changed filter? I have new ones "suck up" and restrict flow enough to not move at all.
It's been awhile since I had one, but the best filters used to be the ones that you could NOT see the filter media as you looked into the pickup hole in the filtr body. You just see the metal of the other side of filter housing. The lower $$ generic ones often plug very easily especially if you have a shift kit with increased line pressure springs or shims in pump.
Also make sure the O rings are in good shape on the plastic pickup tube that the filter attaches to. The ones on the trans end often split and will suck air .
Hopefully you caught it before too much damage was done.
JIM
427Hotrod is offline   Reply With Quote
Old 04-19-2003, 01:17 AM   #3
ORVette
CF Senior Member
ORVette's Avatar
Default Re: Any TH400 experts? Trans. pump whining like crazy...and more! (427Hotrod)
I changed the filter last spring when I installed the B&M trans pak. It was kind of a cheap one, $7.99 for it and the gaskat in a kit I think. Are you saying that the pump is toast AND the filter could be a problem too? Or should I switch the filter and see if that does it (the O rings too)? I did notice that after I put in the kit last year that my 1-2 shift was way firmer, but my 2-3 was actually alot less firm than before the kit. I went in and double checked that I had reassembled everything right, but it was still pretty slushy on the 2-3. I'm getting sick of dropping this pan! One good thing is that I installed a drain plug last year. Thanks for the info, any more is also appreciated.
Old 04-19-2003, 01:34 AM   #4
ORVette
CF Senior Member
ORVette's Avatar
Click the image to open in full size.
Also, just to be sure, this part goes in with the spring up towards the trans and the disc towards the valve body? Right?
Old 04-19-2003, 11:29 PM   #5
427Hotrod
CF Senior Member
427Hotrod's Avatar
I'd for sure try a new filter first. If the filter is plugged it will whine. The only trick is if we caught it before much damage was done. It is common to have some "stuff" inthe pan, but those large metal pieces worry me.
How is reverse? Same clutches are involved as high gear it seems like, so it could be an indicator.
A pressure gauge reading off side of trans would tell you a lot. But I'd try filter first.
THe T-400 is not a hard trans to repair. You might have anew spring project!
JIM
Old 04-20-2003, 02:10 AM   #6
ORVette
CF Senior Member
ORVette's Avatar
Thanks guys. I decided screw it and pulled it out today and took it in for a rebuild. Reverse was kind of messed up too. Had to sort of rev it up to get it to engage. This way I can start over fresh. Only took a couple hours to pull the trans and have it in the back of the truck, so I guess I'm getting good at it. I don't want anymore practice though.
Old 04-20-2003, 10:41 AM   #7
arrio76
CF Senior Member
arrio76's Avatar
Send a message via AIM to arrio76
>Thanks guys. I decided screw it and pulled it out today and took it in for a rebuild. Reverse was kind of messed up too. Had to sort of rev it up to get it to engage. This way I can start over fresh. Only took a couple hours to pull the trans and have it in the back of the truck, so I guess I'm getting good at it. I don't want anymore practice though.<
Pulling the unit is a good decision. Since you have heavy metal in the pan, it was really the only thing to do. It is evidence of some hard part failure and it would only get worse. Hopefully, there isn't too much damage.
Good luck.
arrio76 is offline   Reply With Quote
Reload this Page Any TH400 experts? Trans. pump whining like crazy...and more!
Tags
c4, change, filter, making, pan, pickup, pics, pump, screws, sound, th400, trans, tube, whine, whining
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
