Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-07-2003, 12:48 PM   #1
SharkBit
CF Senior Member
SharkBit's Avatar
Default best bonding adhesive and filler?
im getting ready to do some custom work on my 79, including seamless bumpers, i have the fiberglass bumpers on, but i need some adhesive to bond them to the car, what is a good product to use?
also, what is some good filler to use on the stress cracks, seams, dings, etc?
any help is appreciated....
SharkBit is offline   Reply With Quote
Old 04-07-2003, 07:54 PM   #2
SharkBit
CF Senior Member
SharkBit's Avatar
Default Re: best bonding adhesive and filler? (SharkBit)
anyone?
Old 04-07-2003, 08:58 PM   #3
Last Ride
CF Senior Member
Last Ride's Avatar
Send a message via AIM to Last Ride
Wish I could help you out, but I would like to know this as well. I have heard that it is not a good thing to glass in the bumper covers when I posed a similar scenario a while back. I don't recall the reasoning, but I think it had something to do with variations in the cars. Good luck!
Last Ride is offline   Reply With Quote
Old 04-07-2003, 09:01 PM   #4
PatsLs1vette
CF Senior Member
PatsLs1vette's Avatar
Default Re: best bonding adhesive and filler? (Last Ride)
i use a product called FUSOR,its a great product,i used it to bond my tailight panel in place and repaired my quarters with it also.it bond rather well and easily sands also.theres differnt varietysof it youd have to ask your body supply place and tell them what your doing with it.
PatsLs1vette is offline   Reply With Quote
Old 04-07-2003, 09:42 PM   #5
stpman
CF Senior Member
stpman's Avatar
Default Re: best bonding adhesive and filler? (patsnitrovette)
Pat
where can you get it, I have to repair the taillight panel on the '73 body I have.
Steve :steering:
stpman is offline   Reply With Quote
Old 04-07-2003, 09:46 PM   #6
PatsLs1vette
CF Senior Member
Default Re: best bonding adhesive and filler? (stpman)
i got it from my paint supplier where i get my body and paint supplies.any body shop or supplier will know of it.Fusor its a 2 part system in a tube and you use a gun that shoots out even parts of it and you mix them together and then use it,i use it without the gun just push it up with your finger or a screwdriver and it comes right out..http://www.fusor.com/
[Modified by patsnitrovette, 9:47 PM 4/7/2003]
[Modified by patsnitrovette, 9:50 PM 4/7/2003]
Old 04-07-2003, 09:56 PM   #7
stpman
CF Senior Member
stpman's Avatar
Thank Pat
Old 04-07-2003, 11:59 PM   #8
SharkBit
CF Senior Member
SharkBit's Avatar
i have used fusor before, works pretty well,
thanks pat!
Old 04-08-2003, 12:05 AM   #9
spokewrench
CF Senior Member
spokewrench's Avatar
vette panel adhesive- goto evercoat.com- Lars recommends this- I used it and it worked great- make sure you get the stuff for fiberglass not smc-
spokewrench is offline   Reply With Quote
Old 04-08-2003, 12:14 AM   #10
NHvette
CF Senior Member
NHvette's Avatar
Default Re: best bonding adhesive and filler? (spokewrench)
Here's the panel adhesive I'm using - says it's good for surface filling, too.
Make sure you get stuff that says you can use as filler.
I've never used the Fusor. Is it a 2-part urethane ?
Click the image to open in full size.
NHvette is offline   Reply With Quote
Old 04-08-2003, 01:09 AM   #11
WashingtonRacer
CF Senior Member
Send a message via AIM to WashingtonRacer
Default Re: best bonding adhesive and filler? (NHvette)
I am using the same evercoat, Cost about 60 bucks for a gallon. Just bonded my front end back on last night, This stuff really STICKS!!!! it is also absolultly great for filling, takes about 20 minutes to set, and so far everything is comming along great. By the way, I don't know what is in this stuff, but WEAR A MASK WHEN SANDING!!.. since I have been sanding, I have been getting very light headed while doing this. I have messed with many different chemicals "for the car" and this one has effected me the most. Heck I even have done considrable painting without a mask still was not effected like this stuff did. I've learned my lesson.
WashingtonRacer is offline   Reply With Quote
Old 04-08-2003, 02:02 AM   #12
442olds
CF Senior Member
Default Re: best bonding adhesive and filler? (WashingtonRacer)
I used Aeropoxy to bond my tail light panel and exhaust panel. Its a two part epoxy that you can buy from any Build it yourself air plane kit store (Wicks Aircraft supply in Highland IL is where I get my stuff, but there are others). You can get stuff to mix into the epoxy to make it into a filler, or just thick to fill in corners, you can "wet" it into fiberglass cloth to make bonding strips and what not. It sands well and can be used as a filler with the addition of special additives which they sell as well. It won't shrink either but it does take 24 hours to fully cure.
442olds is offline   Reply With Quote
Old 04-08-2003, 03:11 PM   #13
74-Roadster
CF Senior Member
St. Jude Donor '06
Father & Son St. Jude Donor '09
74-Roadster's Avatar
Quote:
. . . also, what is some good filler to use on the stress cracks, seams, dings, etc?
Grid any cracks, seams or dings out andbuild back up with fiberglass matt, then use the evercoat vette panel adhesive (#870) to fill any small areas. If you fill a crack or a seam with filler, it'll reappear. You must remove the crack and glass the area.
74-Roadster is offline   Reply With Quote
Old 04-09-2003, 12:19 PM   #14
SharkBit
CF Senior Member
SharkBit's Avatar
Default Re: best bonding adhesive and filler? (74-Roadster)
thanks guys, all im waiting on is my hood to begin the process...
i cant wait, hehehe
Reload this Page best bonding adhesive and filler?
Tags
adhesive, bonding, corvette, filler, kingsport, panel, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
