WELL I DID IT PART II
I got the pic's back to day and had a chance to scan them so here you go.
and here is the old link as well http://forums.corvetteforum.com/zerothread?id=525621
Re: WELL I DID IT PART II (Aaron76)
Looks cool. How did you fab a connector to connect to your stock wiring harness? I have a '79 and working on my Ultra-lite gauges, but I am sure I will have to cut the stock wiring harness to. I do plan to make everything quick disconnect though. Thanks
Re: WELL I DID IT PART II (79VetteMike)
the only place where I had to actually splice into the wire was the illumination lights.
But if i remember correctly from my 79 I think it used a printed circut board with just one connector which is different than mine. and one other thing is my small gauges are round where yours have a flat piece on the bottom that you would have to cut out.
TTFN
I wish they made that in a 8 or 6000 RPM version tach. I would get that 10k one and look weird that when I redline it in my Camaro the gauge is only half way
:crazy:
:crazy:
Location: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
:thumbs: good job
