Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-02-2003, 11:55 PM   #1
Aaron-74
CF Senior Member
Aaron-74's Avatar
Default Comp Cams Magnum 270..any thoughts??
Now that my XE-262 is toasted, and I'll be uping the compression. I've been thinking about the Magnum 270. It will allow me to keep the stock stall whichi want to do. And it suposedly give a bad butt idle. Anyways..anyone have any comments on this cam??
Thanks,
Aaron
Aaron-74 is offline   Reply With Quote
Old 04-03-2003, 12:15 AM   #2
ORVette
CF Senior Member
ORVette's Avatar
Default Re: Comp Cams Magnum 270..any thoughts?? (Aaron-74)
When I bought my car it had one stabbed into an otherwise stock L-48 with 3.08 gears. It didn't work anywhere, but it did have a sweet idle.
ORVette is offline   Reply With Quote
Old 04-03-2003, 12:17 AM   #3
Aaron-74
CF Senior Member
Aaron-74's Avatar
Default Re: Comp Cams Magnum 270..any thoughts?? (ORVette)
I've got a very none-stock motor with 3.70'w..
How was the idle quality and did the cam really effect power accesories??
How sweet was the idle?? :reddevil
Old 04-03-2003, 12:34 AM   #4
BB73Chris
CF Senior Member
Send a message via AIM to BB73Chris
I've been kicking this around too... "biggest cam for use with stock converter" does this mean it makes enough low torque to get a good launch with the stock converter or does it just mean the car is kinda still driveable with the stock converter. I've got some '65 fuelie 327 heads I wanted to put on my L48 but 9.7:1 seemed like a lot for the stock cam... none of that really matters to me now though as the 350 is coming out with a noise (sounds like the timing chain is hitting the cover) and I'm finally gonna plug the 396 in :yesnod:
BB73Chris is offline   Reply With Quote
Old 04-03-2003, 12:53 AM   #5
bence13_33
CF Senior Member
bence13_33's Avatar
Aaron:
If you've got the compression ratio to back it up, why not step the cam up? Changing the convertor is not a big deal (other than paying the extra $$ for the convertor itself). At any rate, I have a buddy who has that cam in his 70s Z28 Camaro. It is in a 350 and has a pretty lumpy idle, he also chose the Magnum 270 because he wanted to use the stock convertor.
It just seems like this. If you have the compression ratio and I know you have the rear gears (3.70) to back it up....why not step the cam and convertor up. If you do choose to stay with the stock convertor, I would say the 270 Magnum is one of the better cams you could select.
bence13_33 is offline   Reply With Quote
Old 04-03-2003, 01:03 AM   #6
Aaron-74
CF Senior Member
Aaron-74's Avatar
Default Re: Comp Cams Magnum 270..any thoughts?? (bence13_33)
Good question Bence. I do have the compression,but my heads are the limiting factor right now. Basically I'm running stock L-48 heads with a lot of porting and bigger valves. But they still don't flow SUPER well. And I don't want to get too crazy with the cam. When you start needing a 2500 stall in a daily driver..then it really shouldn't be a daily. And I don't really have the money for the convertor,cooler, all the machine work I need done to the motor along with the new cam and lifters. Comp sales a Mag 270 cam and lifter kit for 170.00$. After that I've got about 400.00$ in machine work to look forward too, probably.
Old 04-03-2003, 01:04 AM   #7
PatG
CF Senior Member
PatG's Avatar
That is the cam in my car but I have a 2200 stall converter. It seems to work nice. If you want a ride just tell me.
Pat
PatG is offline   Reply With Quote
Old 04-03-2003, 01:12 AM   #8
Aaron-74
CF Senior Member
Aaron-74's Avatar
Default Re: Comp Cams Magnum 270..any thoughts?? (PatG)
Hell yeah..
I haven't seen your car in forever. But I always like the way it sounded. I think the last time I saw it was when we all used to meet up on 1960 at the starbucks..
How is the "off the line" power??
Old 04-03-2003, 01:31 AM   #9
PatG
CF Senior Member
PatG's Avatar
I was just over when we pulled the motor out of Ken's car a few weeks back. Power is good but my battery seems to be dead right now. I am going to hook it up to the charger tomorrow to see if it will take a charge, it would not start after driving it so I think it is gone. How soon do you need to make the decision on buying the cam?
Old 04-03-2003, 06:04 AM   #10
Matt Gruber
CF Senior Member
i have the 270 in my 61.
check the book for your stall speed. it is2100 stock on my 72 for example. But the cam is asleep at 1800.
any new cam i buy will be solid lifter.
Matt Gruber is offline   Reply With Quote
Old 04-03-2003, 06:28 AM   #11
Jvette73
CF Senior Member
Jvette73's Avatar
When comp cams says "biggest cam with stock convertor" , in the real world that means run 2500stall. In my opinion, they understate the negitive effects of perf cams on the bottom end. I use to have the XE268 and that cam was listed as "ok for stock convertor", But even with a 2400stall I could feel the loss in bottom end. I wouldnt touch the Magnum 270 in an automatic trans car without roughly 2500 stall. Espesially in a 350. A bigblock 454 would probably be ok without higher stall since they have gobs of tq anyway. Plus, more cubes mellows the negitive effects of performance cams. Thats my opinion.
[Modified by Jvette73, 5:28 AM 4/3/2003]
Jvette73 is offline   Reply With Quote
Old 04-03-2003, 06:39 AM   #12
Jvette73
CF Senior Member
Jvette73's Avatar
Default Re: Comp Cams Magnum 270..any thoughts?? (Jvette73)
2500 stall is very decent in a daily driver. Its a mild convertor. It doesnt stall at that speed all the time. When your easy on the throttle it delivers power long before 2500. The 2500 is brake stall speed. IE when you hold the brake and run the r's up a bit, then simultaenously, release the brake and punch the throttle, then you get the higher stall. And with a 350 and a 2500 convertor, your actual stall speed would probably be less. Stall speed is effected by the ammount of tq an engine produces. So a 350 with a Magnum 270 will have reduced bottom end tq and thus produce a lower stall speed from a given convertor. You might find an advertised 2500 vert, coming in around 2300.
Old 04-03-2003, 07:00 AM   #13
randy72
CF Senior Member
I put one in the engine that came in my 72 (76 8.5:1 305)...before I ran the #'s and knew what it was....it sucked in that engine. No power below 3,000 and the heads didn't flow enough to rev over 4,500...This was a 4 speed car with 3.08's. Idle sounded bad-azz though.
The car was actually more fun to drive with the mystery cam that came in it (much milder, whatever it was) and was faster to boot (16.2 after cam swap, 15.8 before). It did pull well in it's 1500 RPM power-band though...With your higher compression, cubes and head work, you will probably have better results than I did.
randy72 is offline   Reply With Quote
Old 04-03-2003, 07:44 AM   #14
Aaron-74
CF Senior Member
Aaron-74's Avatar
Default Re: Comp Cams Magnum 270..any thoughts?? (randy72)
I had an XE-262 which doesn't seem to be all that much smaller than the magnum 270. about .01 on lift on the exhaust side. Just a tad more durration.
Pat-By next wednesday.
I'll probably just call comp today and pass all the guess work.
Old 04-03-2003, 09:24 AM   #15
vettfixr
CF Senior Member
vettfixr's Avatar
Aaron, as an alternative to the Comp Cams you might want to look at Crane. I have a Crane Max Velocity 272 cam in my 74 and I like it a lot. It has a noticeable idle but pulls nicely on the bottom end and really wakes up at 2000 rpm. I pull 15 inches of vacuum at idle so all the accessories work well. The new nomenclature for the cams is PowerMax and they are listed up to a 278. I can lug this cam down to 800 rpm in 4th gear but the cruise is around 2500. Here are the specs
Crane HMV-272 Max Velocity dual pattern hydraulic cam. The cam has a duration of 216 degrees intake and 228 degrees exhaust @ .050 lift and has a max lift of .454 inches on the intake and .480 on the exhaust. I believe the lobe centers are 114 degrees.
vettfixr is offline   Reply With Quote
Old 04-03-2003, 10:22 AM   #16
1LE
CF Senior Member
1LE's Avatar
I had the 270H in my 77 Camaro with a B&M Holeshot 2000 converter.
The combo worked very well.
1LE is offline   Reply With Quote
Old 04-03-2003, 10:30 AM   #17
SanDiegoPaul
CF Senior Member
Support Corvetteforum!
SanDiegoPaul's Avatar
Location: San Diego - Deep Within The State of CONFUSION!
When I built mine I inquired about getting the "biggest cam I could so to use the stock convertor" too. I had just rebuilt the trans and the torque convertor was new. I wound up with this cam here :
http://dab7.cranecams.com/SpecCard/D....asp?PN=113942
It has a good idle and lots of power. But I wound up getting the 2500 stall convertor later, just to get hole shots. :lol: :blueangel:
So I had lots more labor to go into it and do it twice. :nonod: :nono:
SanDiegoPaul is offline   Reply With Quote
Old 04-03-2003, 10:36 AM   #18
GTR1999
CF Senior Member
I called comp last year about this cam and the XE's 262,268.
I was told with a 350,4 speed,373's use the XE268 with 9.5 and under and the 270 over 9.5 CR.
They said to use the XE268 over the 262 with a manual. I haven't got to that point of the work yet so I can't say how it worked.
Gary
GTR1999 is offline   Reply With Quote
Old 04-03-2003, 11:22 AM   #19
MotorHead
CF Senior Member
MotorHead's Avatar
Location: Never argue with Morons. If you do, you'll lower yourself to their standards, and they'll win, based on experience !!!
Default Re: Comp Cams Magnum 270..any thoughts?? (gtr1999)
Great all around street cam needs 10:1 compression. I could tool around at 1200 RPM in 4th with 3.08's and it still turned on good at the higher RPM's. Real "nice" idle too :D
MotorHead is offline   Reply With Quote
Old 04-03-2003, 12:41 PM   #20
hudman
CF Senior Member
Default Re: Comp Cams Magnum 270..any thoughts?? (MotorHead)
I just had the 270 installed in my BB rebuild. I am picking up the car either today or tomorrow.
I was told it was going to be too mild for my application from some of the forum members, but my engine builder pushed it and so did Comp Cams, so I went with it.
I guess what sealed it is Comp Cams claim that it is the perfect cam for cruising, which is what I do.
Good luck
hudman is offline   Reply With Quote
Reload this Page Comp Cams Magnum 270..any thoughts??
Tags
270, 270h, 270smag, 272, 454, cam, cams, comp, crane, dyno, forum, magnum, max, problems, velocity, xe268
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
