Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-21-2003, 10:29 PM   #1
hgpreston
CF Senior Member
hgpreston's Avatar
Default Oil pressure gauge problems
82 model had mechanical oil pressure gauge in it when I bought it. Held great oil pressure. Factory gauge was sitting at 40psi all the time not even hooked up. Bought new sending unit to hook up factory gauge but fact. gauge is now sitting on 0. Do these gauges go bad or is there something in between causing me not to get a reading. Thanks alot.
hgpreston is offline   Reply With Quote
Old 03-21-2003, 11:16 PM   #2
wombvette
CF Senior Member
wombvette's Avatar
Default Re: Oil pressure gauge problems (hgpreston)
A simple check to see if the guage is good. With the ignition on, pull the wire off. Check the reading. Then, Ground the wire and check the reading. There should be a full deflection. You may have gotten the wrong sending unit. You need one for a guage and not a idiot light.
wombvette is offline   Reply With Quote
Reload this Page Oil pressure gauge problems
Tags
1979, 2000, 79, 82, c3, corvette, engine, gage, gauge, ground, guage, oil, pressure, problem, problems, read, troubleshooting
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1991 Oil Pressure Gauge Question chris1 C4 General Discussion 10 06-09-2005 12:32 AM
HELP!! oil pressure sensor problem... with a new twist. SonnyinVA C5 Tech 9 05-15-2005 10:32 PM
Oil Pressure gauge pegged at 80, Pressue on DIC is 129 lbs? and a wreck:( jlamay C5 Tech 11 12-08-2002 03:11 AM
Need diagnosis: Oil pressure gauge pegs "high". MIKER C3 Tech/Performance 12 11-10-2001 01:02 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
