Intalled Sidepipes- most disappointing day EVER
Old 03-17-2003, 11:09 PM
mastiff
mastiff's Avatar
Default Intalled Sidepipes- most disappointing day EVER
I finally got time to install the sidepipes I got used for $200 (headers, pipes, exhaust). It took me forever, partially because I bolted the new headers on before I realized that I would need to cut some fiberglass on the body to make the sidepupes not rub. I had to take the headers off, and, as most of ya'll know, some of those header bolts are hard to get to.
Anyway, after I installed the headers, I started it up. It was soooooo QUIET! I didn't believe people when they said the Hooker mufflers were quiet- it sounded like a minivan. I had a full exhaust on my car and flowmasters, so it was loud already, but those mufflers made it sound very week.
I also had a couple of exhaust leaks. I didn't want to mess with that at the time so I cruised around in it. Very quiet. I was so disappointed. And then when I got out of the car, I burnt my leg- on the first egress! I now realized why people burn their legs on these things- it looks very hard not too. I'm sure Im going to have to warn every person that gets in the car about the sidepipes.
:banghead: All that time installing the sidepipes and now I'm going to have to take them off to change mufflers. Im going to get a buddy to use a torch to put some holes in the muffler before I go the JCL route. I sure hope that makes it sound better- it sounds pitiful now.
Old 03-17-2003, 11:30 PM
WA 2 FST
Support Corvetteforum!
WA 2 FST's Avatar
Default Re: Intalled Sidepipes- most disappointing day EVER (mastiff)
Andrew,
Sorry to hear about your day. :( That stinks to be disappointed in a modification. Not to add insult to injury, but I'm sure you also lost some power with the Hooker mufflers (whether you got the glasspacks or the reverse flows). I sure did on my 454.
I got the JCL's, got my performance back, and the sound is great. It is very loud at WOT, and nice and grumpy at low-speed/idle, too.
Old 03-17-2003, 11:38 PM
NHvette
NHvette's Avatar
Yeah - that sux - hate to hear bad things about sidepipes.
You should try running them open - just to see how loud they can get.
Don't the tubes unscrew and slide off of the headers ?
Good luck :seeya
Old 03-18-2003, 12:30 AM
mastiff
mastiff's Avatar
Default Re: Intalled Sidepipes- most disappointing day EVER (NHvette)
The first day I was installing them it got dark and I had to drive it home with open headers- no sidepipes. I was setting car alarms off 50 feet away from me. It sounded very cool, but too loud. I was hoping with mufflers it would have the same deep sound, just at a third the loudness.
As for sliding the pipes on and off, I would call it sliding. I would call if more like prying- the only way I get them moving is with a hammer or an extra hand or two.
Old 03-18-2003, 01:33 AM
Desertdawg
Desertdawg's Avatar
St. Jude Donor '09
Well at least you can say you got branded by Corvette.... :lol:
Old 03-18-2003, 05:16 AM
Mystery Machine
Mystery Machine's Avatar
Yeah but side pipes look so darn cool! :p:
Seriously, when I bought my first Harley Davidson I was sooo bummed because it didn't have that signature rumble, then I was told that they all come with stock mufflers and you have to change the pipes out to get that potato sound...so I did and love it! :thumbs:
Just play with them a bit and I'm sure you'll find something you like. :thumbs:
Larry B.
Larry B.'s Avatar
Check out C3 Shark tanks site for some neat inserts, His car sound and runs great. Do a searh for C3 Shark tank... I don't know the link off hand.
Old 03-18-2003, 06:40 AM
SmokedTires
SmokedTires's Avatar
Cruise-In III Veteran
St. Jude Donor '05
I too was very suprised by how quite the Hooker sidepipes were. I will be modding my JCL's when I take everything apart to increase the volume a tad more ;) .
Old 03-18-2003, 08:42 AM
MassVette
MassVette's Avatar
Hooker mufflers cost me 95 h.p. on the dyno..............get the JCL's!
.......much better sound, too!
:yesnod: :chevy :chevy :yesnod:
Old 03-18-2003, 09:14 AM
81ZZ4
81ZZ4's Avatar
Default Re: Intalled Sidepipes- most disappointing day EVER (MassVette)
Side pipes are so cool.
Just open those suckers up :smash:
Old 03-18-2003, 09:16 AM
81ZZ4
81ZZ4's Avatar
Default Re: Intalled Sidepipes- most disappointing day EVER (81ZZ4)
Mass Vette your Mid Year is absolutely beautiful.
My favorite color too.
Sweet car dude. :steering:
Old 03-18-2003, 09:21 AM
Bearcat
Bearcat's Avatar
Mastiff, I had a pair of 30" long spiral baffles made for my Hooker sidepipes that I then just had to pound in for a nice firm fit. And even though I had purchased a complete set like you did, used, I opted to drop another $200 and get brand new sidepipes and I'm glad I did. They slid on and off quite easily until I got everything situated. You might have to get a new pair yourself if your used ones are so tight that they have to be ruined to get back off. And when you do, try the spiral baffles. I think the post above mentioned them. Doesn't JCL make them? I had mine locally manufactured and they weren't much, something like $45 for the pair.
Now about sound quality, they sound incredibly awesome. They are not as quiet as my big block musclecar with Flowmasters, but they sound about as good. I'd say they're about twice as loud as that Flowmaster American Thunder system. And with nothing but spiral baffles in the sidepipes, they are as close as you can get legally to a 4 inch open exhaust.
BTW, I had to do the same fiberglass trimming as you did, but you do NOT have to take the headers off. Just loosen the bolts so the headers sag a little, then get a sawzall and kind of slide the reciprocating blade along the surface of the primary pipe(s) and trim the fiberglass. Then pull the header back into place with a single bolt to check for clearance.
Old 03-18-2003, 12:17 PM
SnoDrgn
SnoDrgn's Avatar
Location: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Been there.. done that.
:seeya
Actually I didn;t burn myself for the first time until the third day I had the pipes on :lol: :yesnod: I think I'm going to buy baffles with my tax return.
Old 03-19-2003, 05:58 PM
Ghostrider
Ghostrider's Avatar
Massvette
Are you using chrome Hooker headers with 4" or 3" Hooker side pipes JCL inserts? I am considering Chromed hookers with 4" but not sure about inserts.
Old 03-19-2003, 06:17 PM
Clink69
Clink69's Avatar
Default Re: Intalled Sidepipes- most disappointing day EVER (Ghostrider)
Massvette
Same as mine, 4" JCL inserts.... I gained around 40 HP from the hooker glasspack to JCLs...
Old 03-19-2003, 06:46 PM
java0881
java0881's Avatar
Default Re: Intalled Sidepipes- most disappointing day EVER (Clink69)
mufflers?who needs stinking mufflers :D
Old 03-19-2003, 07:51 PM
1Bad69
1Bad69's Avatar
Massvette
Jack...if you go the route of sidepipes, then you must not put anything other than baffles in there...if you saw the crap inserts that got pulled out of mune you would know why....baffles are the way to go.. :thumbs:
To Intalled Sidepipes- most disappointing day EVER
Old 03-19-2003, 08:24 PM
Ghostrider
Ghostrider's Avatar
Default Re: Intalled Sidepipes- most disappointing day EVER (1bad69)
1Bad69,
I assume you have Hookers with 4', Who's baffles did you use? CarBelt suggested any of 2 Hooker types (mufflers?) loud and quiet, each $180.
Old 03-19-2003, 11:15 PM
ndirishr1
ndirishr1's Avatar
If you install the original equipment type side pipes with shields do they get hot enough to burn?
Old 03-19-2003, 11:42 PM
sidepipes79
sidepipes79's Avatar
Default Re: Intalled Sidepipes- most disappointing day EVER (ndirishr1)
Well with my pipes, i got burned 2 hours afte rthey went on. I didnt even get to get in the car. I was tuning it and leaned into the. That was a year ago and i still have a mark.
Quick Reply: Intalled Sidepipes- most disappointing day EVER
