Torker II Intake vs. Weiand 7546
Old 03-17-2003, 08:40 PM
69stingray
69stingray's Avatar
Default Torker II Intake vs. Weiand 7546
I found the cam spec card for the engine in my '69. I entered the timing events into Dyno2000 and got approx 232/238* of duration! It have 0.460" lift on intake and exhaust.
Rest of engine: Weiand 7546 single plane intake, stock 3927186 heads (2.02/1.600 valves), stock ram's horn headers. 600 cfm Holley.
Needless to say, it idles rough and has no power below 3500 RPM. And I have hood clearance issues. Would switching to a Torker II manifold help? Would the Torker II increase some low end torque? What should I look for in a used manifold? Are there any issues with “just bolting it on”?
Someday I am going to rebuild with better matched parts.
THANKS
[Modified by 69stingray, 10:21 PM 3/17/2003]
Old 03-17-2003, 09:48 PM
Vetterodder
Vetterodder's Avatar
Default Re: Torker II Intake vs. Weiand 7546 (69stingray)
That sounds like a lot of duration for that amount of lift. Can you post the cam specs from the card? If the cam actually has 323ş duration, it is much more likely the cause of your weak low end than the intake (and probably needs headers to utilize that much duration at higher rpm also). I suspect that you won't see a big difference by swapping intakes.
Old 03-17-2003, 10:02 PM
ddecart
ddecart's Avatar
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: Torker II Intake vs. Weiand 7546 (Vetterodder)
That does sound like a lot of duration for the lift.
fwiw, Ihave a huge cam in my car. 292 advertised duration with 0.516 lift.
I've got a Torker II on my car and a Performer sitting in the garage that's had occasional stints on my car. I can't tell the difference between the manifolds for low end torque at all! My car seems to run better overall with the Torker, so it stays on.
Old 03-17-2003, 10:04 PM
69stingray
69stingray's Avatar
I agree it is the cam. The cam is way to big for stock heads and exhaust. I was thinking that if a get a lower profile single plane intake, it would work better with the heads and exhaust manifold to make up for the too big of a cam. Interesting note, the Edelbrock Torker-Plus camshaft has similar specs, I think.
Click on the image to enlarge:
Intake Open: 7 Close: 45
Exhaust Open: 55 Close 3
Lift @ Valve: 0.460 intake/Exhaust
Duration @ 0.006": 303 Intake/Exhaust
Anyone recognize the part number at the top??
Old 03-17-2003, 10:05 PM
QuickVet
QuickVet's Avatar
Default Re: Torker II Intake vs. Weiand 7546 (ddecart)
that cant be right. way to much duration for a lil old 350. Mine is 300 advertised or 246 at .05 and .515 lift.
That just sounds out of wack and i cant ever remember seeing a cam like that.
Old 03-17-2003, 10:06 PM
QuickVet
QuickVet's Avatar
oops you beat me to the post. still, what does the duration mean at .006???? :confused:
Old 03-17-2003, 10:14 PM
Ganey
Ganey's Avatar
Got it. That's a TRW cam TP112N Chev OEP & CP 232/232 @.050 .460/.460
Old 03-17-2003, 10:23 PM
QuickVet
QuickVet's Avatar
Default Re: Torker II Intake vs. Weiand 7546 (Ganey)
that sounds much better :cheers:
69stingray
69stingray's Avatar
Ganey, I noticed that I screwed up my orig. post just as you were posting. Dyno200 calculated 232 intake and 238 Exhaust duration with 0.05 valve timing.
Do you think the Torker II intake would help at all? Or should I just leave it?
By the way, thanks for the TRW info., off to surf thier website. :seeya
Old 03-17-2003, 11:04 PM
gdh
gdh's Avatar
I have the original Torquer which is a single plane intake like your Weiand. I find that my engine (383 stroker) really starts to kick in above the 3500 rpm range as well but it will fly up to 7000 rpm very quickly. It might be partially a combination of the single plane and your cam. Maybe look at keying in some other dual plane intakes into your DD to see if you like the results better in the low end tq. vs the higher end hp.
Old 03-18-2003, 07:31 AM
Racer16k
Racer16k's Avatar
Maybe advancing the cam would be an inexpensive solution. Also what do you have your ignition timing set at?
Old 03-18-2003, 09:11 AM
Ganey
Ganey's Avatar
I was only on for a moment last night & you are getting good help here & it looked like all that was needed was the actual cam specs. You seem to grasp your situation. Since you want to try to make it "better" easily for more low rpm power, then expect you know there is a removable plenum divider plate for that manifold. Get or make one, try it & report back. Maybe it would help some. As you indicate you know for what you seem to want, expect a new cam.
Old 03-18-2003, 12:31 PM
SWCDuke
SWCDuke's Avatar
Received 1,974 Likes on 1,188 Posts
Default Re: Torker II Intake vs. Weiand 7546 (QuickVet)
Duration at .006" VALVE lift is a SAE standard for duration and is the point where meaningful flow begins/ends. This is what works best with DD2000 for "seat to seat" specs.
The cam is a little too big for the street IMO, but isn't the Torker II a single plane manifold? That's a big problem, too. Street engines should always run dual plane manifolds as they will make more low and mid range torque, which is what you need for a driver. Also, with a single plane manifold, low speed/low load fuel metering is problematic, so you can have driveability problems that are tough to solve.
DD2000 gives more meaningful results if you use a rocker ratio of 1.44:1 for OEM rockers, which is what they actually are at full lift based on my measurements. They actually start out at 1.37:1 as the valve lifts off the seat.
As far as aftermarket rockers are concerned I don't know what they really are relative to advertised claims, but I guarantee you that, like the OEM rockers, the ratio is NOT constant, but varies with lift.
Duke
Old 03-20-2003, 07:40 PM
69stingray
69stingray's Avatar
Thanks for all of the replies.
Since ddecart has already experimented with a Torker II on a large cam motor, I am thinking that switching to a Torker II can't hurt. Now I am wondering if I should just switch to a Performer manifold. The Performer manifold should give me more fuel/air mixture velocity at lower RPM then the torker II. Dave, why do you say your motor performers better with the Torker II?
I did some Dyno2000 experiments last night, here are the results:
The green dotted line is my current engine. Not too impressive. No 375 HP like the 2nd owner thought. Time to update the sig. file! :rolleyes:
1. I tried my engine with a dual plane. Positive torque gain below 3500 RPM.
2. Then I figured that my future engine will have headers, so I tried headers on my current engine. WoW. Greater torque gain throughout the entire RPM. Will header really help lower RPM torque if a kept the single palne?? :confused:
3. Headers with a Dual Plane is next. Just as I thought, same as single plane with headers except more torque under 3700 RPM with less above 3700 RPM.
4. While I am at it, when I rebuild I will install AFR 180. Torque increases when RPM is above 2500 RPM.
5. Finally, my cam for the rebuilt engine. 400 # TQ @ 4,000 RPM. LPE 74211 cam is a roller cam, this graph is with it's spec but hydrallic lifters. When I used "roller cam", torque jumps greatly!
Do you think I should buy headers and call it a day until I rebuild? Can headers be installed with the engine in the car? I think I have heard the engine needs to removed to install headers.
Also, I am not sure what my timing is set at. Any suggestions?
Old 03-20-2003, 08:26 PM
gdh
gdh's Avatar
Install your headers with the engine in. I set my timing at 36 degrees total. IMHO at this point I would put headers on, then match your cam, intake and heads when you are ready, who knows what crank you will decide to go with by then.
Old 03-20-2003, 08:28 PM
Ganey
Ganey's Avatar
You can easily install headers w/o pulling the engine.
Sure you can buy another intake or
...Since you want to try to make it "better" easily for more low rpm power, then expect you know there is a removable plenum divider plate for that manifold. Get or make one, try it & report back.
To Torker II Intake vs. Weiand 7546
Quick Reply: Torker II Intake vs. Weiand 7546
