Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-17-2003, 11:58 AM   #1
Langadorf
CF Senior Member
Langadorf's Avatar
Default Timing Retard - How much lost horsepower?
If I have to retard my timing 7* to avoid engine knock on pump gas, how much horsepower am I losing (assuming I start around 500HP)? Is there some formula to determine approximate losses?
Langadorf is offline   Reply With Quote
Old 03-17-2003, 01:13 PM   #2
Matt Gruber
CF Senior Member
Default Re: Timing Retard - How much lost horsepower? (Langadorf)
a popular question best answered on the dyno.
you go there on pump gas, do a pull, switch to race gas, advance it 7, and you get the answer.
Dyno tuning tips in my sig. link.
Matt Gruber is offline   Reply With Quote
Old 03-17-2003, 02:15 PM   #3
69 N.O.X. RATT
CF Senior Member
69 N.O.X. RATT's Avatar
Location: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: Timing Retard - How much lost horsepower? (Matt Gruber)
On my motor (454) with 450 rwhp and 470 rwt, 2 degrees cost my 3 pds tq and 7 hp. I pulled the timing out from 36 to 34 to see what it would cost me when I shot a little N20 into the motor
69 N.O.X. RATT is offline   Reply With Quote
Old 03-17-2003, 05:32 PM   #4
Larry B.
CF Senior Member
Larry B.'s Avatar
Default Re: Timing Retard - How much lost horsepower? (69 N.O.X. RATT)
I keep seeing this "retard the timing"topic posted.... Actually it is MUCH better to limit the total timing rather than retard the initial. Retarding the initial serves no purpose other than loss of throttle response, hotter running. By limiting the total with a limit bushing in the distributor, you retain all of the low end power and drivability AND get rid of the pinging.. Of course you do still loose some horsepower but that's unavoidable.
Larry B. is offline   Reply With Quote
Old 03-17-2003, 11:25 PM   #5
Vetterodder
CF Senior Member
Vetterodder's Avatar
Default Re: Timing Retard - How much lost horsepower? (silvervetteman)
Actually, it's best to optimize BOTH initial and total, and also everything in between. Optimizing initial is great if you only idle. Once past idle, more timing isn't just desirable, it's very necessary. Though most of us don't spend much time at high rpm, I don't think that many would be eager to give up the serious power losses that would result from reducing total timing in order to have "optimum" initial timing. Recurving the advance curve allows us to "have our cake and eat it too".
Your "11.7" cr is way too high for pump gas and, without reducing it, I think your only option is race fuel. Personally, I'd swap pistons for a lower cr. The power you would gain by being able to run optimum timing would be several time what was lost by the lower cr. While some computer controlled engines may be able to do pump gas with high cr's, they do it by serverly cutting back on timing when they detect knock.
Jason, how much power you are giving up by reducing your timing depends one how much you are reducing TOTAL timing by. If you have a 500 hp (at peak) engine and you reduce advance by 7 from what was optimum, I 'd guess that you are giving up about 50hp. What's the point of paying extra bucks for a more powerful engine if, 1, it isn't fun to drive, and, 2, it can't make the power that you paid for in the real world?
Vetterodder is offline   Reply With Quote
Old 03-18-2003, 01:33 AM   #6
The Dude
CF Senior Member
The Dude's Avatar
It's probably best not to time a retard. The important thing is that he or she tried REAL HARD. And graham crackers. YAY!
The Dude is offline   Reply With Quote
Old 03-18-2003, 05:23 AM   #7
Larry B.
CF Senior Member
Larry B.'s Avatar
Default Re: Timing Retard - How much lost horsepower? (Vetterodder)
I had to take 10 deg. off of the total AND cannot run any vacuum advance. To accomplish that by retarding the initial would have meant 18deg ATDC initial . But that's a BB.....
[Modified by silvervetteman, 5:24 AM 3/18/2003]
Reload this Page Timing Retard - How much lost horsepower?
Tags
1999, advance, c5, c6, corvette, horsepower, hp, loose, lose, loss, lost, retard, retarding, timing, total
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
