69 Wiper door question
Old 02-26-2003, 08:30 PM
telk
telk's Avatar
Default 69 Wiper door question
My wiper door will not open when I turn on the wipers. If I reverse the hoses that go into the can on the firewall the door will open. To close I have to reverse hoses again. Headlights work fine. Any ideas? Thanks in advance.
Old 02-26-2003, 08:49 PM
70ZZ3 96LT4
70ZZ3 96LT4's Avatar
Default Re: 69 Wiper door question (telk)
Under the wiper door and grille on the passenger side is a vacuum relay valve. This valve will not let the wiper door close until the wiper depresses the movement in the vacuum relay valve. This controls vacuum to the vacuum canisster that you are switching the hoses on. I have a original owner 68 and original owner 70 but have never had any problems to troubleshoot yet. Just wanted to make you aware of vacuum relay under the wiper door assembly. Can you raise the wiper door with the override vacuum pull down switch under the steering column? I have read that Dr. Rebuild has a good operation schemetic in his catalog. Good luck.
Old 02-26-2003, 10:07 PM
WATTAC
WATTAC's Avatar
I'll email a diagram I made of my '69 vaccum system. It's in PDF format and will need an Acrobat reader that is generally free on the WEB, unless you already have on installed on your computer.
Andy
Old 02-27-2003, 10:04 AM
Surfer69
Surfer69's Avatar
Default Re: 69 Wiper door question (WATTAC)
Can I get a copy too WATTAC? THX
Old 02-27-2003, 12:27 PM
RCB69L36
RCB69L36's Avatar
Andy
Me too. Send it my way. Thanks.
:thumbs:
Old 02-27-2003, 12:31 PM
thejaf
thejaf's Avatar
Default Re: 69 Wiper door question (RCB69L36)
have you checked the switch under the dash?
Old 02-27-2003, 03:40 PM
MYBLU71
MYBLU71's Avatar
Andy
:seeya Me, Too.. :seeya
Old 02-27-2003, 06:10 PM
telk
telk's Avatar
Default Re: 69 Wiper door question (thejaf)
You mean the override switch? Yes nothing happens.
Old 02-27-2003, 11:11 PM
dennis-trapp
dennis-trapp's Avatar
mee too
Thanx
Dennis
Old 03-06-2003, 04:58 PM
Dr Z
Dr Z's Avatar
Default Re: 69 Wiper door question (dennis-trapp)
You can find a (1970, but that didn't change from 69) vacuum diagram at http://www.corvettes.de.vu (yes, that's my site and yes, it's a shameless plug for it :D ) plus some other stuff. (The diagramm is filed under resources - Data, I believe).
Cheers,
Chris
To 69 Wiper door question
Quick Reply: 69 Wiper door question
