Header Installation
Old 02-12-2003, 01:40 PM
L82-JWS
L82-JWS's Avatar
Default Header Installation
Considering installing a set of headers on my ZZ4 in the 79. Can this be done without yanking the engine? Any tricks to this? I have 4 speed with true dual exhaust. Thanks fo the advice in advance!! :confused:
Old 02-12-2003, 02:39 PM
Alwyn678
Alwyn678's Avatar
Default Re: Header Installation (L82-JWS)
Sure should not be a problem at all. At least it was not on my 74 W'air
Old 02-12-2003, 02:44 PM
MasterDave
Moderator
MasterDave's Avatar
Instructions come with the headers. The main thing is they have to be installed from the bottom so you need to jack it up high enough to do this. Then there's the plug wire routing, not a problem really just making you aware. Do you have straight plug heads or angle plugs? Angle plugs are gonna be a pain as the wires hit the headers and you will need shorter plugs. :cheers:
Old 02-12-2003, 03:19 PM
J75
J75's Avatar
Default Re: Header Installation (MasterDave)
Angle plugs are not a problem if you route the wires in the stock[against the block]location.Ihave TF angle plug heads with Hookers and the wires are not close to touching.And yes the headers were an easy install from below.
Old 02-12-2003, 03:20 PM
fauxrs
fauxrs's Avatar
:iagree:
You will have to remove the clutch linkage - regardless of which brand header you have ordered - so pay close attention to its assembly. - come up from below - you dont have to go too high off the ground - even ramps would most likely be enough. You may or may not have to remove the starter motor.
It is easier if you have a friend who can start the header bolts at either end of the header while you hold it up in the air from below.
Hookup may require a slight s-bend to hook up to your existing system.
Old 02-12-2003, 07:19 PM
L82-JWS
L82-JWS's Avatar
Default Re: Header Installation (fauxrs)
Excellent info....thanks.....
To Header Installation
Quick Reply: Header Installation
