Ok I give, 700 shift plate mod
Old 03-18-2011, 03:34 PM
Dave5701
Dave5701's Avatar
Default Ok I give, 700 shift plate mod
I hear it is easy, but would like to know just what is involved and what to do. I just want to mod my existing shift plate in 79 L-82. I put in a 700R4 and want to get to first gear. Is it as simple as filing/cutting back the rear edge to allow the shifter notch tooth to go farther back?
Old 03-18-2011, 03:44 PM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
did you see the pictures i posted of it? let me look for them...
Old 03-18-2011, 03:55 PM
bobs77vet
bobs77vet's Avatar
http://forums.corvetteforum.com/c3-t...4-install.html
heres the link the detent picture is in this....i had the two detents are reverse images accidentally just print the picture and cut it out and then turn it over so you can compare them to each other
To Ok I give, 700 shift plate mod
Quick Reply: Ok I give, 700 shift plate mod
