Do duals running through a cat flow any better than single exhaust?
When exhaust from the factory started running through a cat like the pic does it flow any better than single exhaust or was going to duals after the cat strictly cosmetic?
cosmetic , dual cats was the answer
The following 2 users liked this post by Eric P:
brassplyer (04-06-2024),
zwede (04-04-2024)
Because duel exhaust looks awesome!!! But......
dyno test 420HP V8, 2.5" dual exhaust vs 3" single exhaust. Both combos are also tested with turbo mufflers vs flow-through (Magnaflow style) mufflers.
The following 4 users liked this post by Mdbirk:
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Regarding the dual pipes and mufflers after the cat, I suspect Chevrolet figured the noise compliance from two big mufflers was worth the money, (Chevrolet never spends money unless it has to) and the two pipes (and large mufflers) were one of the few methods available back then to keep from losing any more of the already short supply of horses in the engines back then. Remember, an exhaust system is a series of resistances to flow. It is not just one piece of the system that causes all the restriction to exhaust flow.
I changed the Catalytic Converter due to issues with the original. I replaced it with a Unit from Summit that flowed almost twice whet the original cat was capable of. It warmed up faster and helped my C4 get 30 mpg while using the emissions system. By using the new catalytic converter my exhaust system sounds great as the exhaust system has a cat back Chambered Pipes System. It sounds ferocious even for a L98 engine. The aftermarket HI Flow catalytic converters were less than I thought, mine was a bit over $200.
Since I keep the car with regular plates I have to keep the emissions system fully functional.
By comparison, today’s cats are quite good at their primary function but are much better flowing, smaller, lighter, cooler, and far less expensive. If Chevrolet had today’s cat technology back in the seventies, they may well have installed two cats per car and continued with the two sets of full length pipes of previous model years. The HP would have rated higher as well for all engines.
1979 L82 M21 FE7
Classic White / Doeskin
brassplyer (04-11-2024)
There is now a market for High Flowing catalytic converters and I doubt that any of the hi-flowing catalytic's will cause back pressure. The difference on my C4 was amazing as the body was 50% larger and still fit down there. The C4 runs great and gets good mileage with absolutely ZERO Drone..
I guess like anything it depends on the combination of parts and what works best in what situation. I didnt push the thing with high rpms or anything but The torque /acceleration just seemed noticeably stronger after replacing the hollowed out cat which did have an exhaust leak. The truck had 35" mud tires and 4.56 gears but even with the gears the old 5.9liter magnum was no bullet.
