C 3 Turn Signal Lever replacement
Cruising
Can anyone advise me on how to remove and replace the turn signal lever on a Tilt/ telescopic column in a 1979 corvette.
Not the turn signal mechanism, its OK. But the bent lever is very wobbly and I want to replace it with a straight lever.
I have dismantled the steering column down to the removal of the signal mechanism which is out of the column but I can't see how to remove the lever.
Any help would be appreciated. Thanks.
Received 4,574 Likes
Cruise-In VIII Veteran
The lever itself just pulls straight out. No need to dissassemble anything.
Cruising
Thanks 4-vettes, I have tried to pull the lever straight out but it will not budge even after lubricating with WD40. I can rotate the lever a fraction but if I apply too much pressure it will break down near where it enters the solid housing.
Is there a retaining clip or something else to push or press to dislodge the lever ?
Received 1,302 Likes
If your car is equipped with cruise there is also a small wire and connector that will need to be disconnected.
Cruising
Thanks everyone for the advice. With heat, a little lubricant and a mighty heave it came right out and the new one just pushed straight back in. Thanks again.
4-vettes (03-20-2024)
Glad to hear you got it!
