Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-26-2003, 12:20 AM   #1
Sigforty
CF Senior Member
Cruise-In IX Veteran
Sigforty's Avatar
Send a message via AIM to Sigforty Send a message via MSN to Sigforty Send a message via Yahoo to Sigforty
Default How many coats of clear do you put on paint??
I was talking to my mechanic/painter about my car today. I wanted to have alot of clear put on the car, but he says 3 is about all you want to put on. He also said more coats will cause cracking and problems. What do yall say? Oh, and by the way I got a look of the Steel cities grey paint and it rocks! I like the greenish tint to it.
Mark B.
Sigforty is offline   Reply With Quote
Old 01-26-2003, 01:02 AM   #2
Roadster71
CF Senior Member
Roadster71's Avatar
Default Re: How many coats of clear do you put on paint?? (Sigforty)
I put four coats on mine figuring that at least one would get sanded and buffed off. Seemed to work out real well.
Roadster71 is offline   Reply With Quote
Old 01-26-2003, 02:01 AM   #3
LAvetteman
CF Senior Member
St. Jude Contributor
Mark, the first coat is usually a tack coat (light). Then most put 2-3 heavy coats after that.... I would say no more than 4 total. But hey, every painter has his preference.
LAvetteman is offline   Reply With Quote
Old 01-26-2003, 02:06 AM   #4
lbell101
CF Senior Member
lbell101's Avatar
Go by the manufacturers recomendations. I almost always spray 3 coats but 2 to 4 should work. I wouldn't go past 4 coats and I wouldn't go to 4 if you aren't going to color sand. Your painter is correct that thicker films probably crack easier (especially on Vettes). Problems I encounter with higher builds are solvent poping (craters caused be escaping solvents) and puddlies (can't remember the tech name right now) an uneven surface with a large texture (like great big smoothed out orange peel).
Larry
lbell101 is offline   Reply With Quote
Old 01-26-2003, 02:13 AM   #5
LAvetteman
CF Senior Member
So Mark, will your 71 be ready for Gonzalas in late Feb?
Old 01-26-2003, 11:48 AM   #6
Sigforty
CF Senior Member
Sigforty's Avatar
Default Re: How many coats of clear do you put on paint?? (71,454,4spd)
That is the plan. I was looking at the car this weekend. So far all the fiberglass is on and all the suspension is straight. The hold up right now is a few power steering parts I chose to have replaced. While the guy was in there doing work I had the front end rebuild with bushings and ball joints. The guy told me it should be two-three weeks left. That is in waiting for parts, installing them, preping the body, and painting.
Mark B.
Old 01-26-2003, 12:05 PM   #7
R1234
CF Senior Member
R1234's Avatar
Mine has 4 coats of base and 3 coats of clear.
R1234 is offline   Reply With Quote
Old 01-26-2003, 01:02 PM   #8
lars
CF Senior Member
lars's Avatar
Location: At my Bar drinking and wrenching in Lafayette Colorado
Mark -
Your painter is correct - the thicker the paint, the less durable it is. Yet, you want enough clear on it so it can be colorsanded and buffed without the risk of cutting through. The modern urethane clears go on very thick, so sand-through and buff-through is not much of a risk. I do a tack coat with two full wet coats on my paint jobs. This is more than plenty to assure adequate thickness for sanding and buffing, yet it keeps the mil-thickness down to a reasonable level for excellent durability. Anything more than this is non-value-added.
lars is offline   Reply With Quote
Old 01-27-2003, 01:52 AM   #9
paintdaddy
CF Senior Member
paintdaddy's Avatar
Default Re: How many coats of clear do you put on paint?? (lars)
:iagree:I put 4 and sand one off in the buffing stage :yesnod:
paintdaddy is offline   Reply With Quote
Old 01-27-2003, 03:51 AM   #10
'79ProwlerOrange
CF Senior Member
'79ProwlerOrange's Avatar
Send a message via AIM to '79ProwlerOrange
Default Re: How many coats of clear do you put on paint?? (paintdaddy)
3+ the tacky 1st :thumbs:
'79ProwlerOrange is offline   Reply With Quote
Old 01-27-2003, 08:57 AM   #11
Sigforty
CF Senior Member
Sigforty's Avatar
Thanks for the info Lars, and everyone else. I really do not know paint that well so I was wondering. As far as color coats my painter has a gallon of paint and plans on using it all. The same for the clear. He said the gallon should work out to around 3 coats. I just wanted to make sure I was getting enough on the car.
Mark B.
Old 01-27-2003, 10:54 AM   #12
R1234
CF Senior Member
R1234's Avatar
Mark,
It's a good idea to have some extra paint left over for any touch ups that might need to be done at a future date. I have an extra quart left over. This quart was mixed in with all the base paint that was used. Insuring me that if I have to use it, the tint should be the same. The painter that I used had just finish repainting a car that someone had painted with the same color paint but out of different cans that were not mixed together. You could see the different shades of paint on the car.
Old 01-27-2003, 12:44 PM   #13
RMVette
CF Senior Member
RMVette's Avatar
Mine has 3 base and 4 clear. :)
RMVette is offline   Reply With Quote
Old 01-27-2003, 01:58 PM   #14
Gotta Fix my '76
CF Senior Member
Gotta Fix my '76's Avatar
Send a message via AIM to Gotta Fix my '76
Mark,
This is from House of Kolor...one of the leading custom paint job manufacturers and painter trainers in the world/or/ North America...
"What is the correct House of Kolor clear coat for my project?
House of Kolor provides two clear coats that cover all VOC requirements. UC- 35 is a fast drying, high-build clear coat. UC-35 is the first clear coat you should apply in you custom paint job whether it's over UK Kandy, House of Kolor base coats, graphics or artwork. After the UC-35 has dried for at least 24 hrs., wet-sand with 600 or P800 to remove all the gloss, imperfections and orange peel that may have occurred. After cleaning the sanded surface, remask and apply two to three coats of UFC-35. Allow the clear coat to cure then color sand to a polish. This system will provide the best gloss and DOI (distinctiveness of image) to your custom finish. Never apply more than three coats of urethane clear at one time without letting it cure color sanding or reclearing. Excessive coats of urethane clear applied wet on wet will result in splitting, die back, soft film and delimitation. This is a case where more is not better!"
Read here at the end...."More is not better" I've been looking into painting as well and that is what I've read as the general rule as well...
Good luck, and can't wait to see how it turns out..
~Ian :yesnod:
Gotta Fix my '76 is offline   Reply With Quote
Old 01-27-2003, 01:59 PM   #15
Gotta Fix my '76
CF Senior Member
Default Re: How many coats of clear do you put on paint?? (Gotta Fix my '76)
sorry, should've posted the link
http://www.houseofkolor.com
Old 01-27-2003, 10:54 PM   #16
CF6873
CF Senior Member
Unless the basecoat color is a poor hider I would think a gallon is too much. Basecoat only needs to cover the primer and the clear gives the durability. Some painters use check hiding stickers which is black and white checks. These are placed on a masked surface along side of a panel being painted. When the black and white is no longer detectable the amount of base is sufficient. Any more than that is wasted and not adding to the integrity of the paint job. Craig
CF6873 is offline   Reply With Quote
Old 01-27-2003, 11:09 PM   #17
LAvetteman
CF Senior Member
Default Re: How many coats of clear do you put on paint?? (CF6873)
:iagree:
Old 01-27-2003, 11:42 PM   #18
paintdaddy
CF Senior Member
paintdaddy's Avatar
:iagree: with the paint system that I use,one gallon of basecoat makes 3 gallons after it is mixed with the reducer. :seeya
Old 01-28-2003, 09:04 AM   #19
Sigforty
CF Senior Member
Sigforty's Avatar
From what I understand the paint is already mixed. All the painter needs to do is pour it into the gun and start spraying. He said he plans on 3 coats or both base and clear. So I think I will be alright. I was the one thinking about having him put on more clear. So I feel all will be good now that I know not to force him to do it. Someone I saw posted getting some extra paint for chips and all. I think I am going to try and do that.
Mark B.
Old 01-29-2003, 10:07 PM   #20
Pete76Shark
CF Senior Member
Support Corvetteforum!
Pete76Shark's Avatar
Taking my 76 to the paint shop next Monday. Jeff says 2 base coats of bright white. then 2 coats of pearl, then 3 clear coats. I saw a car he did with the same paint. Bot does it look good, almost like white metal flake
Pete76Shark is offline   Reply With Quote
Reload this Page How many coats of clear do you put on paint??
Tags
bumper, car, check, clear, coats, corvette, custom, gallon, hiding, paint, painted, painting, put, stickers, urathane
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
