Oil pan gasket issues
Navigator
I have a 383 stroker with maybe 500 miles on it and I can not get the oil pan gasket to seal in the front. I have a chrome oil pan and an aluminum timing chain cover. I have tried 3 different thick front gaskets. Does anyone know of a gasket brand that is known to be a little better at sealing the front?
There are two different thickness gaskets and engine size has nothing to do with it. Read this to determine the correct gasket to use.
https://www.speedwaymotors.com/the-t...o-i-need/28651
The following 2 users liked this post by C3 Stroker:
leadfoot4 (12-23-2023),
sunflower 1972 (12-22-2023)
Received 1,908 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Yep..I'd buff off the chrome where the gasket seals....use the right gasket and use some "Right Stuff" as a sealant with the gasket across the front.
JIM
JIM
Go Vette Go (12-25-2023)
Try to use gasket SHELLAC sealer.
https://www.permatex.com/products/ga...compound-2-oz/
I used it on chrome auto transmission pan and there no leaks.
Avner
Received 2,155 Likes
This issue is somewhat common on chrome Timing Cover, Chrome Valve covers but real common on chrome water-necks and chrome oil pans.
There is not a RTV (or rubber) in the world that will stick to slippery chrome.
As others have said, remove the chrome in that area.
Love chrome parts. Have it almost everywhere on the engine. However, never could understand the reasoning for a chrome pan, on a low riding car like our Vettes.
Who can see it?
Who can see it?
Ok I guess I'd better remove my chrome pan on the engine and the transmission and the timing cover. They're all gonna leak
Oh, wait... they've been there for 10 years and no leaks....weird. Oh and the valve covers...what to do?
carriljc (12-24-2023)
Clarification:
Remove the chrome in the "gasket / RTV sealing area."
I did none of that. They will seal, you just have to have the right size gasket. If you want to insure sealing a little ultra black works good. The right stuff is the same just in a pressurized can.
saying that chrome won't seal is just not an accurate statement.
Dr. Detroit
Received 3,897 Likes
What pan gasket are you using?
Jebby
Eight out of ten won't. You got lucky.
It's i. The prep if you want sealant to seal.
If 8 out 10 won't seal then I got lucky at least 8 times. 2 valve covers removed and replaced multiple times same gasket, one trans pan, one timing set cover removed 3 times and one pan removed 2 times. None have leaked on any of those occasions. So I just don't know where this chrome leaks idea is coming from.
Right. It's just people's imagination that they leak.https://www.google.com/search?q=do+a...t=gws-wiz#ip=1
The following 2 users liked this post by sunflower 1972:
C3 Stroker (12-25-2023),
HeadsU.P. (12-25-2023)
^^^ Exactly ^^^^^
Chrome water-necks are the worst. Nothing a belt sander can't fix.
The only chrome engine parts that never leak are a chrome dipstick and a chrome air cleaner lid.
Which I have both.
Which I have both.
sunflower 1972 (12-25-2023)
The following 2 users liked this post by REELAV8R:
carriljc (12-26-2023),
DarrellD23 (12-25-2023)
Received 4,683 Likes
Cruise-In VIII Veteran
Good! Glad we have that settled!
now onto things that help.
Sometimes aftermarket pans really are not made the very best. Scratching up the chrome a bit right on the gasket surface can often help with a troublesome pan.
using a light coat of "the right stuff" often does help.
Ultra black and the right stuff are NOT the same. You can purchase the right stuff in a tube just like ultra black. Both are good sealers. The right stuff seals like a bank vault.
I've removed most of the Chrome on my engine not because of sealing, but rather it just doesn't hold up in this tropical humidity.
Navigator
Hello
Avner
Avner
I think I will remove the chrome from the front crank timing chain cover lip that is leaking.
Should I also use the Shellac sealer along that entire lip or just install the gasket the way it was intended?
Dr. Detroit
Post a picture of the oil pan....
Jebby
Jebby
