Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-24-2003, 12:08 PM   #1
Brettmc
CF Senior Member
Brettmc's Avatar
Send a message via AIM to Brettmc Send a message via Yahoo to Brettmc
Default How much oil does a 454 hold...which oil filter?
How much oil does my 74 454 with stock oil pan hold? Also, which AC oil filter do I use?
Does it take AC R45TS plugs? What gap if I have an MSD 6?
Brettmc is offline   Reply With Quote
Old 01-24-2003, 03:29 PM   #2
sray454
CF Senior Member
sray454's Avatar
Default Re: How much oil does a 454 hold...which oil filter? (Brettmc)
5 qts - same as all other V8's
Not sure which Oil Filter #, but I always use the overpriced good ones ...
sray454 is offline   Reply With Quote
Old 01-24-2003, 04:00 PM   #3
PRNDL
CF Senile Member
Support Corvetteforum!
PRNDL's Avatar
Mark Jackson @TraderJaxon
Send a message via AIM to PRNDL
My owners manual (68) says 6 qts with a filter change for my 427. The AC Delco PF-25 is the standard filter. PF-35 is bigger. They may have changed the numbers recently. MJ
PRNDL is offline   Reply With Quote
Old 01-24-2003, 05:21 PM   #4
paul 74
Ontario, Canada
paul 74's Avatar
Default Re: (MNJack)
Those Delco product numbers are still valid.
Click the image to open in full size.
paul 74 is offline   Reply With Quote
Old 01-24-2003, 06:23 PM   #5
73 LS-4
CF Senior Member
73 LS-4's Avatar
Mine always seems to go a little over 5qts, more like 5.25-5.5, I normally gap my plugs around 40 with my ignition system.
:cheers:
Pat Kunz
73 LS-4 is offline   Reply With Quote
Reload this Page How much oil does a 454 hold...which oil filter?
Tags
08, 1978, 1999, 427, 454, 74, bbc, corvette, engine, gen, hold, liters, motor, oil, take
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
