Electric Choke Wiring Best Practice
You didn't list year in your profile or post but see if you have a spot in the fuse box that has a spade marked IGN. I used that with an inline fuse and ran it through an existing grommet in the firewall that you can see under the dashboard.
GM used a relay in my 80, on a 20 Amp fuse. Best practice would be to do something similar. The relay can live under the hood, and be fed from the alternator (with a fuse), but I'd be wary of pulling too much from your fuse panel.
A typical Holley electric choke uses a 10 Amp fuse and actual tests of amperage draw saw no more than 7 initially after which it dropped to about 2.
Your numbers align with what I saw. I suspect GM picked their 20 Amp fuse to be conservative on cold days.
Still, there is a relay, not a direct connection.
MelWff (11-28-2023)
Received 3,222 Likes
As far as sizing a fuse-
The fuse is just there to blow before the wire melts- not to protect the devise connected.
So you'll want to match the wire to handle to current draw of the devise and the fuse to protect the wire.
And it's not an issue to use a smaller fuse and bigger wire- but not vise versa
Also- don't use the "primary" wire sold at autoparts stores- it's only rated at 180º
You'll want to use a cross poly link type wire rated for 256º - SXL-GXL-TXL
Fuse /wire chart
SXL = Standard
The thickest insulation of the three, SXL is good for high-temp spaces like engine compartments where space is less of a concernGXL = Thin
This is generally used in high temp spaces where flexibility and reliability are needed. While it is thin walled, there is a thinner option.TXL = Extra Thin
TXL is the thinnest option, making it ideal when space is at a premium. Extra thin wall also makes it lighter than the others.Fuse /wire chart
Received 1,297 Likes
I usually purchase the GXL...
The TXL will save you space when bundling...
For Comparison, both are 14 gauge
I did not go to the fuse box, I grabbed power from the wiper motor plug, it's switched with the ignition, I rarely drive in the rain, the wipers are never on when I start the car, inline fuse and good to go...
60
60
The following 2 users liked this post by 1860army:
james casello (12-02-2023),
speedreed8 (11-29-2023)
I did the same as 1860 above when installing an electric choke conversion on my 69. I spliced into the yellow wire on the wiper motor plug which is keyed on with the ignition. I didn't use an inline fuse as the wiper plug is already fused. I tried a test initially with the wiper switch on at startup and everything worked normally. I've had it like that for over 5 years and never a fuse problem.
