Question on Raised port BBC heads
If I went with a .300" raised exhaust port will that effect the alternator bolt that attached to the headers? If so is there a work around for the alternator bracket?
Dementer sole survivor
Received 6,367 Likes
2016 C3 of Year Finalist
what heads are you looking at and what size motor and cam are you running....If you are running a 427 and keeping th ehorsepowerr under 600 look at Brodix Race Rite heads with a 270 intake Oval ports...good heads, stock exhaust locations. Edelbrock has some heads as well with stock exhaust ports.
