Good fuel pump source?
Working on a '73 SB car. The auto parts store pump is putting out 13 pounds and blew the Q-jet's brains out.
Does anyone know a supplier they've had good experience with? Need not be 100% correct, though I'd take it as well.
I haven't used them but, I've heard good things about them: https://robbmcperformance.com/products/chevy550.html
Dr. Detroit
Received 3,893 Likes
Jebbysan (10-11-2023)
Is the Delphi from the same factory that makes the Carter branded pump? Have a new Carter and its putting out over 9 lbs. Needed to add a regulator due pump caused QJet issues
Check out this thread before you purchase.
Mapman
https://www.corvetteforum.com/forums...uel-pumps.html
