Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-20-2003, 09:23 PM   #1
StingRay327
CF Senior Member
StingRay327's Avatar
clintondjohnson
Send a message via MSN to StingRay327
Default Smell like Exhaust after driving???
Whenever I get done cruzin I always end up smelling like exhaust, all most as bad as you do after snowmobiling. I have new O ring gaskets and manifold gaskets so I don't think there's any leaks. I always cruz with the windows down too. Does anyone else seem to have this happen?
StingRay327 is offline   Reply With Quote
Old 01-20-2003, 09:28 PM   #2
Gordonm
CF Senior Member
Gordonm's Avatar
Default Re: Smell like Exhaust after driving??? (StingRay327)
All the time. Even when the top is down
Gordonm is offline   Reply With Quote
Old 01-20-2003, 09:41 PM   #3
Rich80
CF Senior Member
Rich80's Avatar
Mine smells. I know she runs rich especially on warm up buy what the heck for 142,000 wonderful miles..... :cheers:
Rich80 is offline   Reply With Quote
Old 01-20-2003, 09:44 PM   #4
Smokehouse69
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
Smokehouse69's Avatar
My car used to make me smell like I'd just crawled out of the muffler, but after sealing the firewall, installing new manifold gaskets, and fixing all the tiny exhaust leaks, the smells went away.
Smokehouse69 is offline   Reply With Quote
Old 01-20-2003, 09:47 PM   #5
SanDiegoPaul
CF Senior Member
Support Corvetteforum!
SanDiegoPaul's Avatar
Location: San Diego - Deep Within The State of CONFUSION!
Default Re: Smell like Exhaust after driving??? (Smokehouse69)
If I send you my address, a plane ticket, and my birthdate, can ya make it?
SanDiegoPaul is offline   Reply With Quote
Old 01-20-2003, 09:49 PM   #6
Zack Wenning
CF Senior Member
Zack Wenning's Avatar
Send a message via AIM to Zack Wenning
I have wondered about this before too. I dont usually mind it when it's just me but, I often take the vette out on dates and out with friends. My passengers often mention the smell. The time it bothered me most is when I drove it to my senior prom and we were all dressed up and were lookin :cool: , but we smelled like exhuast :( .
I wonder if the intsallation of 2 high flow cats would correct the problem without compromising too much of the original sound and nonoriginal performance. :cheers:
Zack Wenning is offline   Reply With Quote
Old 01-20-2003, 09:58 PM   #7
SanDiegoPaul
CF Senior Member
I know that mine has air leaks all around :reddevil :mad because when I drive it on a cold night the air whistles thru it like a hurricane!
But when I have no exhaust/header/collector leaks it is a whole lot better. :steering:
Old 01-20-2003, 10:10 PM   #8
Smokehouse69
CF Senior Member
Default Re: Smell like Exhaust after driving??? (SanDiegoPaul)
Paul, it would be a lot cheaper for you to do it yourself, than to fly me out to fix it. :D
Put a light inside the car with it on jack stands. Turn the light on, and turn the garage lights out, crawl under the car and start looking for light. If you see light, plug the hole with black 3M Electical Putty. You should be able to find it at Home Depot, Lowe's or some place like that.
Do this to both sides of the car. You'll get most of the leaks if you do this.
It only took me about an hour to do both side of the car, and 90% of my leaks dissapeared.
This won't take care of leaks coming in from the ventilation system, but they usually don't let fumes into the car.
Old 01-20-2003, 10:17 PM   #9
Gotta Fix my '76
CF Senior Member
Gotta Fix my '76's Avatar
Send a message via AIM to Gotta Fix my '76
Smokehouse69,
Very Practical...I like it...I'll have to try it...Thanks for the idea...Hopefully I'll be seeing only darkness from the underside of my Car... :seeya
Gotta Fix my '76 is offline   Reply With Quote
Old 01-20-2003, 10:22 PM   #10
Teuffelhunde
CF Senior Member
Teuffelhunde's Avatar
Default Re: Smell like Exhaust after driving??? (Gotta Fix my '76)
I've got 4" side pipes and the exhaust smell is almost inevitable. It's great when my wife drives the car though, the smell, um. . .arouses me. :yesnod:
Teuffelhunde is offline   Reply With Quote
Old 01-21-2003, 01:05 AM   #11
74FLCONV
CF Senior Member
74FLCONV's Avatar
Default Re: Smell like Exhaust after driving??? (Teuffelhunde)
Hello...my name is Danny and I have E.O.
D. Ocean
Miami, FLA
74FLCONV is offline   Reply With Quote
Old 01-21-2003, 12:38 PM   #12
Makonut
CF Senior Member
Makonut's Avatar
Default Re: Smell like Exhaust after driving??? (74FLCONV)
My 70 does it. But I have sidepipes which doesn`t help. I did lean it out some and quite a bit of the smell disappeared.
Makonut is offline   Reply With Quote
Old 01-21-2003, 06:07 PM   #13
joeveto
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
joeveto's Avatar
I don't know what's worse, the smell, or hearing my wife scream, yet again "You Stink!" I'm going to try the suggestion above, and see if this helps. Thanks for the advice!
joeveto is offline   Reply With Quote
Old 01-21-2003, 08:43 PM   #14
dlw
CF Senior Member
Exhaust smell? Thats redneck eau-de-toilet aint it?
Add me to the list of stinkers too. What I found on my car was unburned fuel at idle when I first start it up. I always stand away from the car till its warmed up a little and that seems to help some. But, with side pipes and the top down the only cure is to go fast!
dlw is offline   Reply With Quote
Old 01-25-2003, 05:51 PM   #15
The Money Pit
CF Senior Member
The Money Pit's Avatar
I never gave it much thaught till I read this post. Funny, when I walked in the kitchen my wife said I smelled like a gas station the same day I read it.
The Money Pit is offline   Reply With Quote
Old 01-25-2003, 06:07 PM   #16
Robert N
CF Senior Member
Robert N's Avatar
Default Re: Smell like Exhaust after driving??? (The Money Pit)
Two things come to mind. First is leaks and second is too lean/rich a fuel mixture.
If the mix is too lean, you tend to get more hydrocarbons released. That is the heavy exhaust smell that hangs in the air and on your clothes. If you smell like 'gas vapors', the mix is too rich.
Adjusting the mixture eliminated all smell from the car. The wife even had to ask if I drove the car last week and she walked into the gargae 5 minutes after I returned.
Robert N is offline   Reply With Quote
Reload this Page Smell like Exhaust after driving???
Tags
car, chevy, corvette, driving, exhaust, exsuast, gas, putty, smell, smelling, smells, stink, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
