Specs, Bleeding Technique on Early C3 Master Cylinder
Looking at pictures of early C3 master cylinder #5455509 for manual (non-power) brakes...
1. The #5455509 had bleeders right above the outlet lines. I'm assuming these function for bench bleeding purposes? Whether on the car or on the bench - that would be super-convenient... (and see follow-on question 3 below)
2. What is the bore diameter on the #5455509 brake cylinder used on non-power brake early C3s?
3. Generic question - bench bleeding a typical master cylinder (w/o extra bleeders as above). After bench bleeding - when disconnecting the bleeder lines and connecting the actual brake lines - don't you always re-introduce a little air? Clarify that step?
Received 2,144 Likes
Part 3.
Yes, when you disconnect the kit from the MC, a bubble or two is always introduced into the system front & rear before you can attach the brake lines. Its unavoidable.
So the entire vehicle has to be bled. All six bleeder screws.
Part 1. Rumor has it that the MC with attached bleeder screws was for the assembly line. Only certain yrs had that design.
Bleeder screws on the factory master cylinder are used on the production line to fill the system but not used in service.
Replacement master cylinders many times do not have them. Some rebuilt GM master cylinders will obviously have them but you dont use those screws for anything.
pgtr,
I don't believe that's how it works. Maybe. IDK
I believe those bleeders are inlets not outlets. So, air is still behind the brake-line fittings.
1. You would have to block the outlet ports so no point.
2. Bore is 1"
3. After attaching the lines you can crack the bleed screws to bleed any that got in to the master but still have to bleed all 4 calipers.
2. Bore is 1"
1" got it - thanks.
I was thinking that the outlet lines would essentially be 'blocked' if hooked up to the calipers. Further (assuming bleeders are tapped into same outlet lines) was thinking any air bubbles exiting the M/C outlets would travel 'up' and thus out the M/C bleeders.
thx again
thx again
Looks good on paper.
Murphys Law says otherwise.
And if your were going to try and "bench bleed" the MC on the car you will need to make sure the back of the MC is higher than the front of the MC to make sure you get all the air bubbles out - by jacking up the rear of the car.
Pat
Pat
Get the last bit of air out from the brake master cylinder. - CorvetteForum - Chevrolet Corvette Forum Discussion
