3 or 4 rows on 75 Corvette radiator?
Finalist 2021 C3 of the Year - Modified
How many rows on a stock 1975 radiator ?
Getting ready to order and see lots of different options.
Received 4,570 Likes
Cruise-In VIII Veteran
A standard L48 had 2 rows. But get as much radiator in there as you can shoehorn in! Who cares what it came with. Put in what will work! You can't have to much radiator!
But you can have to little!
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
Get an aluminum rad with 2 rows of 1-1/4" tubes which supposedly cool better than a 4 row rad. That's what Dewitts premium rads have, the 2 rows type. I had a Cold Case rad with 2 rows of 1-1/4" tubes. Engine ran at a steady 180*.
Mark.uli (08-10-2023)
I run a 4 row Champion. I live in a extremely hot climate. With my C5 fans and a very warmed up 350. Everything runs cool. Less rad. Not so much.
when I first moved here I had a stock replacement rad. Worked on the edge in Wisconsin. Not close here.
Then a lesser Champion. Better, but didn't like 100 degree F. And up weather. Then I realised that cheaping out on a radiator is just foolish.
biggest rad you can shoehorn in there! On those Hot days you'll be glad you didn't save a dime!
One thing to note, you can have the biggest radiator that fits, but things like
improper timing/missing air dams and seals/collapsing lower hose
will all cause overheating issues regardless of radiator
The following 2 users liked this post by randallsteel:
augiedoggy (08-05-2023),
JimmyHill (08-08-2023)
I just replaced my OEM brass radiator with a Dewitts aluminum radiator. It's great. Not cheap, but I felt it was worth it for my '78 Corvette (original owner, 90K miles). Lifetime warranty, American-made,
From what I read from others on the Forum, I think you get what you pay for, if you're willing to shell out the bucks. Make sure whatever you buy will fit.
Lot's of good advice here. And yet no one mentions the stock rad configuration!
there are different opinions here. But a constant consensus.
Who cares what the original rad had! It wasn't good!
