18 x 10 18 x 9.5 BS dilemma
Hi guys
i'm going to purchase a set of Classic V's from Team 3/ET. I just wanted to run a backspace question past you good people incase anyone else has the same/similar setup
I'm going with -
Front - 18 x 9.5 275/40/18
Rear - 18 x 10 285/40/18
The current wheels are 17" Vintage Wheel Works V40's, i'd love a set in 18's but they don't seem to make them.
I've put the rear wheels from my Dad's 69 Camaro on the front of the Vette (17 x 9.5, 5" front space), I've then tried with a 1/4" spacer and a 1/2" spacer and they both work (albeit with rubbing at full lock from stationary, it's rubbing on the inner well and brake line, I can move those). No rubbing in general or hard driving. It's a pro touring Vette.
So i'm torn between -
18 x 10 either 5.5 or 5.75 BS (with corresponding equal front space on the front wheel to keep the same dish).
My car is quite low and I don't want any tire coming past the arch, 5.5BS seems to be popular but they always seem to be on cars with higher ride height, anyone got that combo?
I can't mock up a 5.5" BS rear Camaro wheel on the rear of the Vette because the wheel studs are too short (will be replacing with 3" ARP studs. I could mock up a 5.75 BS though.
Any thoughts are appreciated.
Pic is with 9.5" front wheel.
Cheers!
Oh also anyone out there with tri-bars (spinners, knock offs) on an 18" wheel? Not sure whether its going to look tacky or awesome!
I'm going with -
Cheers!
Hi guys
I'm going with -
Cheers!
I'm going with -
Cheers!
Wheel size 18x9.5 with 4.75" BS no mods anywhere. With factory sheering did lock @ front due to from spoiler not perfectly setup. When changed to Flaming river R&P less turning radius, didn't matter.
the difference with 275 vs 285 rear you will not notice , square all around lets me rotate tires front & rear for best tire life ( trackdays )
The following 3 users liked this post by cagotzmann:
Use this calculator to compare.
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
If you know your wheel specs take measurements, then play with the calculator to get the right offset for your car.
aaroncorvette (07-04-2023)
Hi Aaron - long time no speak. Do you really need to use spacers.......always a potential weak point........On the rear end of my '68 I'm using 285/40/18 on a 18 x 9" rim with a 5" backspace......no wheel spacers - and stock trailing arms........OK, so its really needs the trailing arm bushes replaced very soon and with the wheels being on a few years now the trailing arms appear to be deflecting during heavy cornering with the inside of the rear tyres lightly 'polishing' the frame......
I'm still not decided on BS, will have another mock up with Dad and let everyone know what occurs.
My 78 with E-T Wheels LT-III
The following 2 users liked this post by cagotzmann:
aaroncorvette (07-11-2023),
Z0Tex (07-05-2023)
Hi Ross, how are you doing? Funny I was going to text you earlier as I remember you had 18" wheels, I was hoping they'd be 10" wide. The spacers are only for mocking up and to simulate different front and backspacing, although I do have a run a 1/4" one on the front at the moment.
285/40/18 tyres are starting to get a bit expensive here in UK.......as someone has noted there is negligable difference in width/rolling diameter with a 275/40/18.......they are less expensive and more available.
As this stage of your tyre.wheel search I'd be inclined to consider 'stepped' rear tyres......perhaps 20's or 21's......theres some nice wide options available (at a price).......crystal ball job though to choose a tyre/rim combo that'll still be available in 10 years time!
Rims
Hi Ross.
I bought the tyres a while back. I kept an eye out for 265,275 and 285/40-18’s. I have all three sizes sitting in the garage.
Michelin Pilots and Pirelli Pzero.
holley505 (07-11-2023)
They’re all part worn from EBay. I rarely buy new tyres. I look out for tyres max 4 years old and with 5+ mm of tread. Amazing how much you save. The Michelins were £130 a pair💪. It’s not a super car so it doesn’t matter.
Search Accelera tyres Aaron - very reasonably priced - good reviews - not such a comprehensive choice of sizes but way, way cheaper than 'named' tyres!
2019 C3 of Year Finalist (track prepared)
Great wheel choice. I love the ET wheels.
I did 18x10 with 5.5 bs all the way around. I used 285/35r18 Nankangs. I get a slight rub on left front frame near the steering box bolts when really cranking the wheel hard left at low speed. It's a small price to pay for me. You may not be ok with it though. I could probably use a 1/4 inch spacer up front to pull the tire away just a little more.
The following 3 users liked this post by jimco84x:
So it’s looking like -
18 x 9.5 front 5”BS. Giving me 5.5” front space
18 x 10 rear 5.5BS giving me 5.5” front space.
so I have the same front space front and rear.
Old Pro Solo Guy
You may want to mock something up in the rear and double check clearance.
IIRC a 5.5 bsp wheel gets really close to the parking brake bracket and it may need to be moved to the top of the trailing arm.
aaroncorvette (07-08-2023)
You also need to allow for tire flex during high speed cornering. for me this is track days.
Here is 4.75" Backspace , and 3 important locations in the rear to fit.
#1 at the spring.
#2 Parking brake cable.. Or you will have to relocate to the top of the trailing arms.
Rear sway bar if installed.
