I need tuning advice please!
Have you checked if the outer ring on the harmonic balancer has slipped causing false timing readings.
Dr. Detroit
Received 3,893 Likes
Lean has nothing to do with it......verify timing first before you do anything else........you are shooting for 15 initial and 36 total....or close to that......lock it down and diagnose other issues. The timing numbers are a standard baseline for ALL small and big block chevrolets.....and should not deviate far from that......big bores want more total, big cams want more initial......
If you are experiencing issues with running after the timing is spot on then you need to troubleshoot further...such as vacuum leaks or carb jetting......I see you are running a Holley.....
Jebby
It has a big lopey cam in it, at the most, how much advance should it have both initial and total? Here is a link to what it is.
https://www.summitracing.com/parts/lun-60105
Don’t be afraid of a lot of timing. Low compression motors with a lot of cam overlap like a LOT of timing. Really rough Rule of thumb is if the motor likes it, keep adding until you get pinging under light load at cruise. Then back off a little.
I have a crate motor with 8:1 compression and an L82 spec cam. I can run high 20’s initial with vac advance and into the 50’s all in with vac advance, and a decently smooth idle. With the vac advance disconnected and 14 initial and 36 all in it idles like a pro stocker but is really lazy on the low end.
I have mine set at 22 initial with a big cam. After that I had to readjust and tune the carb a little to get it just right.
Dr. Detroit
Jebby
Alright got the total set to 36 degrees around 3000 rpm. At idle (about 1000 rpm) it's still at 22 degrees. Since it has so much timing at idle I just left the vacuum advance on the ported side of the carb. TDC was also verified correct. Couldn't find bushings to fit the stock advance weights so just installed the advance kit weights and middle piece with the medium springs. It now is back to just having the slight stumble if while you're driving along steady and then give it more throttle. I'm assuming it needs more accelerator pump shot.
#33
Dr. Detroit
Once you do that, run a slack adjustment on your accelerator pump arm. The Ultra DP 650 has 63/73 jets 28/31 squirt.....if you are still stumbling.....add 2 numbers to the primary and a 31 primary squirter with the tubes......
Jebby
#34
Ok that all sounds good. Just out of curiosity, why the higher advance like that at idle? Does it make the idle even stronger? I am running vintage air and when the compressor kicks on it will not hold an idle. Maybe this will help? Otherwise I need to try the idle step up.
Right now the primary jets are 64 and the pump shot is a 31. Maybe try 66 jets and 34 shot?
#35
#36
Dr. Detroit
Jebby
#37
Your fuel burns slower under less pressure and turbulence. When you have a cam with a lot of overlap (the period in which both intake and exhaust valve area open) You have a loss of compression at less than peak torque RPM. Every cam has a loss of pressure due to overlap, just more so with a large cam. So the fuel burns slower due to compression loss, swirl loss, lack of turbulence etc.
In order for an engine to produce it's peak power at a given RPM it needs to reach peak pressure approximately 17* after top dead center (ATDC)
If the fuel is burning slower then it needs to be ignited earlier in order to reach peak pressure at this time. Any timing that achieves that peak pressure before or after that 17* is a loss of power.
So when you are idling the fuel is burning slower taking longer to reach is max pressure. If you want it to reach max pressure at that 17* ATDC then the fuel needs to be ignited earlier.
That is why more ignition timing is needed at idle. Lacking that and you get hesitation, low power, low idle vacuum, greater throttle displacement needed to idle, perhaps to the point of engaging the main circuit which in turn makes it idle rich, on and on and on.
For a street driven engine you need to get the IDLE timing right in order to get your idle and off idle performance correct. It has to be right to get the idle jetting right.
I do not believe that idle timing is incidental to the total of 36* total timing. It is important and critical to a large portion of the driving you are going to be experiencing in a street driven car.
Chagjr (06-23-2023)
#38
Dr. Detroit
Jebby
MelWff (06-23-2023)
#39
I know it doesn't but he was complaining of an off idle stumble.....squirt and jet size does effect that.....squirt is important but jet has a role as the fuel needs to get started through the booster.....a larger jet helps that IF the jet is too small to begin with....
Jebby
Jebby
Jebbysan (06-27-2023)
#40
The jet change alone has gotten rid of the stumble. Engine seems to be running really nice right now. Definitely want to thank everyone for the help! I am trying to get the car done before Good Guys in Des Moines this weekend. I did a ton of work to the car to get it ready. I think I'm actually going to make it. Thanks!!
