What is this “Nudging” sensation felt at cruise?
1974 L-82 4-speed. When cruising or light acceleration around 2000-2500rpm I get this sensation of pulsing and nudging, it’s hard to describe. It sort of feels like the secondaries are wobbling and I get a slight boost then it drops back. The tac and speedo remain constant and do not reflect this. Any thoughts y’all?
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I recall having the same problem with my '76 which was years ago. Not sure how a got the fix but I replaced the vacuum can on the distributor which completely solved the problem. The diaphragm inside the can was probably leaking.
Dr. Detroit
Received 3,893 Likes
It is called trailer hitching and is caused by either improper distributor timing, too much vacuum advance or a combination of both......
Pull hose from vac advance cannister and plug.....drive the car and see what it does......if the trailer hitching disappears....there it is.
At that point I recommend checking timing per Lars papers.......go from there.
Jebby
Jebby
The following 4 users liked this post by Jebbysan:
Great, thank y'all for the help! I will look into the vacuum advance since I recently switched from port to manifold vacuum so maybe the old diaphragm couldn't handle it.
St. Jude Donor '06-'09-', '22
Good, current discussion in C2 right now on this topic...
https://www.corvetteforum.com/forums...g-problem.html
Hmm, mine did this with my brand new electronic distributor. Turned out to be the weights had the tightest springs on it. Came with 3 sets so I put the middle ones on and solved the issue. I also got the distributor because I was having alot of pinging at 8 degrees timing were it should be, so got a new one hoping it would help. No better on pinging, so research told me to retard the timing. I dropped it to 6 degrees and it made a huge improvement. Still a bit of ping so Im probably gonna try anothe 1 or 2 off the timing. Guess my point is the manuals timing spec isn't always right. Mines say 8 but its clear its gonna be 4 to 6.
ctmccloskey (05-19-2023)
I thought I'd post what I ended up doing about this for anybody experiencing this. Now I'm sure the folks and their suggestions above are correct, but my particular issue was caused by a poor air/fuel mixture. I used a gunson colortune and got that engine running just like a song. This trailer hitching issue went away, and significant acceleration increases were felt.
St. Jude Donor '22
"Gunson Powertune" ?? Never heard of this tuning tool. Went to their website. Interesting. Can you explain how you used it to tune the AF mixture. Curious. My guess was like others, too much vac advance.
Certainly! I borrowed the gunson colortune from my buddy working on a 240z where he was struggling to get the correct air/fuel mixture with the twin carbs. It's just a spark plug with a glass window where the ceramic normally is, and a little mirror at 45 degrees that lets you actually see the combustion. The tool comes with a little color scale card (like what's in a litmus test) that shows what different colors of the combustion represent. Yellow color meant rich and white meant lean I believe, with the correct mixture giving "bunsen burner blue". I was running very very lean, a couple turns of each screw got me to bunsen burner blue. Super easy, and fixed my trailer hitching hours before I had planned on buying a new vac advance can like y'all suggested haha.
Dr. Detroit
Jebby
Thanks for that info. Learn something new all the time. I have heard that you need to get your AF mixture sorted prior to setting up timing advance. But wouldn’t the Gunson only give you idle mixture readings?
