Powermaster XS Torque Starter Install
Good evening from East Texas. I have a 1978 base L-82. I have just installed new heads, headers, exhaust, intake, distributor along with Powermater XS Torque model #9500. Finished the install on all of the new parts and had to go with a smaller started due to clearance issues. Went with one suggested by Corvette Central but actually purchased from Summit Racing. Clocked the new starter and went to re-connect the battery and fireworks started. Disconnected the battery, then the starter. Re-connected the battery, no issues. Took starter to Summit Racing where they gladly replaced. Reinstalled and the same thing happened. FIREWORKS! Now I have to replace the negative battery cable. Has anyone experienced this issue in the past? Am I overlooking something? I did not have any issues prior to the mechanic work. Oh, I did not have the distributor or the alternator connected.
Like
Comment
Send
Like
Comment
Send
Received 2,144 Likes
If Peterbuilt is reading this he will chime in with a picture of the solenoid posts, lugs, cables and correct wiring installed.
I suspect one wire is in the wrong spot.
Peterbuilt (03-30-2023)
Cruise-In IX Veteran
How are you connecting it? The powermaster XS only has 2 lugs. The big lug gets the power from the battery and the small one gets the trigger wire from the ignition. The ground wire with the starter wires should be on a bellhousing bolt.
I installed it just as you described.
Is the big lug(power wire) touching the engine block? Or touching any other metal that would short it to the engine or to the housing of the starter?
If you are getting sparks with it hooked up that way, I would look to see if something is touching. I know the earlier c3 has a 90 degree power wire from the battery that requires some bending and insulation so it will not touch the starter body.
Received 1,252 Likes
Do you have the correct replacement starter?
https://www.summitracing.com/search/...eyword=starter
HeadsU.P. (03-30-2023)
I bet a power cable to the bottom lug would look like 4th of July.
And I bet people have done it accidently.
Like
Comment
Send
Like
Comment
Send
John
