Speed direct spreader bar with van steel tubular upper arms.
Just went to install my speed direct spreader bar on my van steel tubular upper a arms. Seems the mount is a bit too long and does not lay flat because the ends go over where the bushing are. Any thoughts?
ex
ex
Received 3,149 Likes
Add another / thicker washer to get it to clear would be my first thought. Grinding / cutting the end of the mounting bracket so it doesn't go out that far would be my second.
M
M
