Dart Pro 1 Aluminum Heads
Old 01-12-2003, 02:50 PM
69vette66
69vette66's Avatar
Default Dart Pro 1 Aluminum Heads
Howdy I was wondering if anyone is using the SMC Dart Pro 1 Heads on their vette with Hooker side mount Headers. These Heads Have angled Spark plugs. Do they have a clearance Problem with the header. :cheers: I am trying to decide with head to go with angle or straight? Thanks Larry
Old 01-12-2003, 06:57 PM
The Money Pit
The Money Pit's Avatar
Default Re: Dart Pro 1 Aluminum Heads (69vette66)
I went straight with the AFR's because no one could give me a straight answer. The fact is most Vettes with sides,are running stock heads,which are straight,and just want the car to look and sound hot. Which the pipes will do.!
On the heads,I paid $1350. for the AFR's,a difference of only around $200 at the time between the Pro One's.
Old 01-12-2003, 11:55 PM
69vette66
69vette66's Avatar
Default Re: Dart Pro 1 Aluminum Heads (The Money Pit)
Thanks Money Pit. It looks like there is room enough for angle plugs with my headers. I need at least 230cc. For a 421 roller motor that I am Building, These heads i found are230cc with all the goodies Titanium Retainers & Locks, and All the machine work has been done. plus I may be able to purchase them from a friend of a friend for around $850. To good to pass up. Never used. Its hard to believe somebody hasn't ran into this problem yet? will they or will they NOT fit Small Blk With Hooker side mount headers, Part #2234HKR I only have a few days to decide, because somebody else want them if I don't. I got first dibs :cheers: :cheers: :cheers: Thanks Larry :cheers:
Old 01-13-2003, 08:27 AM
SmokedTires
SmokedTires's Avatar
Cruise-In III Veteran
St. Jude Donor '05
HI 69vette66, I too am considering those same heads (227cc CNC ) for my current engine buildup. I currnetly am running Sportsman II with angled plugs on my 350 without any problem mounting the Hooker Headers, so my next head will also be angled :) .
Old 01-13-2003, 10:34 PM
69vette66
69vette66's Avatar
Default Re: Dart Pro 1 Aluminum Heads (SmokedTires)
Thanks SmokedTires, They looked like they would clear with no problem. I just wanted to make sure.
Larry
Old 01-13-2003, 11:25 PM
nastee383
nastee383's Avatar
Larry
Just remember, all angle plug heads don't have the same angle. I've had Trick Flows and my current SportsmanII's. The Hedman headers I used to have fit completely different with each set of heads and they were both angle plugs. The Trick Flows were VERY close on 3 of 8 plugs while the SportsmanII's were slightly close on only 1 plug.
Old 01-14-2003, 08:37 AM
BeaterShark
BeaterShark's Avatar
Default Re: Dart Pro 1 Aluminum Heads (nastee383)
To give you another data point, I have not clearance problems with AFR head with the L98 angled plugs.
I'll go out on a limb and say that I believe any angled head can be made to work with the Hooker side pipe headers with the shorty plugs if push comes to shove.
To Dart Pro 1 Aluminum Heads
Quick Reply: Dart Pro 1 Aluminum Heads
