Electrical puzzler...
I am sure everyone here remembers Click and Clack and their puzzlers...
I have one for you. I am trying to trace an electrical issue,
When I am cruising at 80MPH and hit small bumps and unevenness in the road, the dash idiot lights flicker on including both turn signal lights, the high-beam and, I think, the brake warning.
I am thinking something in the steering column... That harder the bump the brighter the idiot lights come on. Tough to tell, but I think the headlight beams maybe flickering off as well.
As far as I can tell, the engine seems to be unaffected.
Either way - I will be yanking out the steering column very soon for a rebuild. The hazard switch seems stuck and non-functional, key buzzer does not work and horn randomly comes on too.
MTIA DC3 !
MTIA DC3 !
rmrtrex (10-04-2022)
Received 4,573 Likes
Cruise-In VIII Veteran
A loose ground causing lights to come on? Lights that need power to come on and are always grounded?
Not thinking a loose ground wire is the answer here.
Something is sending power to those bulbs. both signal indicator lights are on separate circuits. And high beam indicator is an intirely different circuit again.
If it was just the signal indicators coming on I might suspect the signal switch in the column.
But with high beam and possibly the brake warning light in the mix. I would be pulling drivers side dash out and inspecting the harness behind the speedo and tach for damage.
Ha !!!! Interesting - where would this dash ground be ?? I don't recall seeing it when I took the dash apart.
EDIT
Bingo
EDIT
Bingo
the none that says "ground wire"?
plus the fact you don't remember it implies you don't remember connecting it...
SS327 (06-30-2022)
...then I urgently need to take a leak
rpiechowski (08-31-2022)
Not my car - but what I’m looking for. Another 1969.
I checked under my dash… I could not see well. I’ll have to remove the seat at the very least.
After having removed the seat and steering column for another project… I found that the ground wire is there and looks very healthy.
Hmmmmm.
Hmmmmm.
wadenelson (08-28-2022)
I’m guessing this is it and it’s not looking terribly fresh.
Still haven’t cleaned that little strap under the car.
I took it for a test drive today. It seems less the bumps than the speed. Once I hit 85 MPH, the hazard lights come on and stay on. Weird !
Do you have a heavy keychain? Does the janitor look at your keychain with admiration?
A heavy keychain will wear out the ignition switch by swinging, over time.
When ignition is briefly lost, all the idiot lights come on just like they do before you crank the engine.
Try driving with just the key. If problem goes away replace the ignition switch.
Since the cylinder's prolly worn out by now I'd replace the cylinder, key, AND switch. Having a different key than the door gives you added security anyway. Thieves can't take a slide hammer to your passenger door cylinder while you're in a restaurant, go make a key, come back and start the car.
Or you can pay a locksmith to re-key the new cylinder you buy from whoever.
W
Problem solved.
YW
I've been to this rodeo a few times, although not on any Corvettes.
W
W
Forgot completely about it until I saw your post.
Lighten up those key chains.
