Your drill bit of choice for drilling on a carburetor?
As I'm about to drill into my Holley Brawler throttle body for boost referencing, it occurs to me I should probably have some better drill bits lined up than the bargain set from Harbor Freight. Having one break off would be the worst possible scenario.
What's your favorite bit brand for drilling metal? I'll get several of the same size, I plan to use a drill press.
Thanks!
Thanks!
brassplyer (03-20-2022)
The following 2 users liked this post by Indigoblue:
brassplyer (03-20-2022),
Rescue Rogers (03-20-2022)
Nam Labrat
Received 4,216 Likes
True. H.F./etc. are too brittle.
Drill/ream the hole VERY slowly...
any drill ( bit) could snap when "breaking thru"....
use "aluminum friendly" drilling-cutting oil.
Use dial caipers or microm. to verify drill bit diameter
Your initial Drill should be what's called a Center Drill. Especially if the surface is not flat. Assuming its Aluminum You can use most any drill from there.
Turns out my concerns were unwarranted. The material of the carb body is very soft - using oil and going a little at a time the bit went through it like butter. The cheapie Harbor freight bit likely would have done fine.
augiedoggy (04-02-2022)
cheapie harbor freight cutting tools would have a hard time doing a clean hole in a bar of irish spring soap...but in reality the only bit i would trust on a carb is one that has Lars holding the drill...
JBrooke825 (04-02-2022)
We like to crap on HF but now days they have at least 3 different drastically different grades of bits. if you buy the cheapest ones its a crapshoot but the better titanium grade bits really are decent. Same with their tools now. The icon line is the same stuff they sell as cobalt at lowes.. Not snap on but not bad either.
I have a small set of Hercules bits for my Hercules power drills and they have given me no issues.
that said your braver than me drilling holes in a new carb
What makes me cringe are the guys on Youtube videos that do it freehand, no oil they just plow on through eyeballing it. I used a drill press to ensure it went straight.
As long as the hole ends up where it belongs if at some point you no longer want it boost-referenced you could just plug the hole with tank putty.
You are working on aluminum, so you don't really need the greatest high quality bits for such. The key to aluminum is oil as you do, and go slow. Clean the bit of shavings also as you go. On aluminum don't push on the drill, but let the bit cut.
