Removing the GLASS from side view mirror
Has anyone removed the side-view mirror glass from it's housing and successfully re-installed? I have two (2) LH-side mirrors (I'm sure both are aftermarket), and the one without the "glass" (it's actually plastic!) fits the bracket/base on the door fine, but the one with the glass just doesn't fit correctly - the set-screw doesn't line-up. The base of the two mirrors must just be slightly different, although not obvious when examining. I would like to swap over the glass to the assembly that fits if it's feasible.
By the looks of the assembly without the glass, a hobby store - type of hot glue was used to adhere the glass. I'd guess applying heat would be used to soften, but I don't want to discolor the glass. Also, when re-adhering, would you recommend just using a hot glue gun or something like JB Weld???
I'm sure I'll eventually buy a new set, but reviews from various suppliers' websites indicate that most are China-Junk and USA-made are out-of-stock.
Thanks for suggestions!
DR'76 (02-27-2022)
agree
see sport here
https://www.corvetteforum.com/forums...xperience.html
Replacement glass cheap and of high quality..cheaper than the gas..
see sport here
DR'76 (02-27-2022)
DR'76 (02-27-2022)
Try lacquer thinner. Put the mirror face down in a metal pan, cover with aluminum foil and put it outside. The mirror should free up in short order. Jerry
DR'76 (02-27-2022)
