A6 Compressor Gasket
My A6 compressor had a gasket that held 2 filters for the connection of the manifold (hoses) to the compressor. Unfortunately it is gone. Any ideas of where to get a replacement>?
The original A6 had two O-rings that sealed the manifold, and one mesh filter on the inlet.
The O- rings are a dime a dozen, but the steel mesh filter is no longer available. There is only 1 filter on the A6 compressor. No gaskets either. for a while they sold 2 gaskets to seal the main valve plates inside the comp, but found they were not needed.
Dom
Dom
Dom
Dom
Edited: Sorry, been searching for OEM gaskets/seals/rubber washers that went between the main hose and compressor ('72) and been hitting brick wall. OEM probably not available? O ring will work? Have tried what I could find, 1 1/8, 1/8 thick. Would like some a bit thicker though. Thanks
Pull your old O- rings out and go to a auto parts and they all should have them. try and get the green HNBR ones. The mesh filter (only one is on the inlet (drivers side) they usually are clean.
Dom
Dom
kansas123 (10-16-2021)
